Koni Yellows Perch Adjustments, please read
Ok well im happy that my koni shocks give me an excellent ride and comfort but the drop doesn't look even anymore, the front is higher than the rear. i want to raise up the rear to make the drop even(the rear has less than a finger gap and the front has a 2 finger gap).
there are 3 perch levels, right now they're all on the middle one. if i put the rear on the perch level that raises the car, how much will it raise it? how much does each perch lower/raise the car by?
thanks
thanks
what kind of springs? If you have eibach's they tend to sag in the *** alittle bit. You could lower the front to compensate instead.
i have neuspeed sports/koni yellows. when i only had the springs, my drop was perfect(almost even). now that i put the koni yellows, the front stayed the same but for damn reason the rear is lower. i dont like the rear to be that low, thats why i want to raise it. the rear has almost no wheel gap and it looks kinda ghetto(i dont like very low cars, looks like i cut my springs or something).
u know what im saying?
so you guys think that by rasing the rear by one perch will correct my problem?
