FS: The Cleanest Turbo D-Series Hatch in NY
So, lets get on with the show...
1995 Honda Civic Hatchback DX
Exterior:
Milano Red repainted less than 2 years ago. Paint is still superb.
Painted mouldings, spoiler and door handles.
Wings West Urethane front lip (black)
JDM headlight housings, with black corners
VIS Carbon Fiber Hood
Tints all the way around
14" Civic SI Steelies
Foglights
Undercoated
Interior:
Red/Black Del Sol Seats
Tenzo Steering Wheel (I still have the stock wheel)
JDM Shift Boot (Black w/ Red stiching)
Trust Shift ****
Reverse Gauges
4 Polk Speakers w/ 2 MA Audio Tweeters and Sony Amp
Code Alarm Alarm System and Keyless Entry
Power Windows (aftermarket)
Power Locks
Belltronics FX2 Performance Timer
Whister Radar Detector (hardwired, and sensor is in the front bumper )
Autometer Gauges (Boost and Oil Pressure)
HKS Turbo Timer
JDM Center Counsel
Custom CF Gauge/Turbo Timer Counsel
Re-upholstered door inserts (Black Suede)
Did I mention Del Sol Seats
Suspension/Brakes:
Omni Power CoiloversKYB AGX Shocks
SRR Rear Tie Bar w/ Sway Bar mounts
Front sway bar
Front strut tower bar
Integra Disc Brakes (front and back)
Brand New Integra Master Cylinder (3 months old)
Brembo Blanks
Engine:
D16A6 block
Z6 head
Eagle Rods
Vitara slugs (8.5:1)
Ported 14B turbo with small 16G hot side housing
Custom Log Style Turbo Manifold
2.5" Down Pipe
2.5" Exhaust
2.25" Charge Pipe
Bar and Plate Front Mount
1g DSM BOV
DSM Injectors
Tuned with Crome
New Battery
SPR Manual Boost Controller
K&N Turbo Air Filter
Belkin Spark Plug Wires
NGK Spark Plugs
Sweet Red Distributor
Sweet FMIC Water Spray Set-Up
Suspension Techniques Shifter Bushings and Motor Mounts
ACT Clutch
Lightened Flywheel
Spare 95 EC tranny w/ 4.9 SRR final drive & Phantom Grip LSD included
Running 16 PSI, rougly making 300ish whp.
- I replaced a lot of little things here and there (ex. Vehicle Speed Sensor, and did a valve lash adjustment).
- Oil has always been changed every 2500 miles, and the turbo timer is always used. I have never boosted it while the car is cold.
The Bad:
It burns a little oil. It is most likely the valve seals which would be about a $250 job. It burns roughly a little less than a quart every week to week and a half. It really isn't that bad. I check it every few days and add it here and there. You just really have to watch it.
It could use a re-tune of the A/F. The idle is a tad stumbly at times, but it has never died on me, or cause the car to stall out. Mike at Innovative already said he would do it, and it shouldn't you over $100.
There is a scratch in the driver side fender, which i have touched up. But it could stand to be repainted.
The car still drives nice and pulls like a raped date.
The NYSPEED.COM logo has been taken off.
While it has never been tracked, I think its safe to say that this car is easily in the 12's and puts bus lengths on GTOs, EVO's, STI's, Modded C5 Vettes etc etc.
Except for the few guys on the local racing forum, there was nobody I ran into over the summer that even had a chance.
The car has never left me stranded and has always started up. (Except for when the Optima blew up).
If I don't sell it, I will dump more money into it over the winter. But with where my life is taking me right now, I kind of just want to have a nice DD.
Onto the pics:
I only have pics without the CF Hood, and with the wheels on it.
$6,000 or Best Offer.
Trades will be considered.
I will get pictures with the CF Hood on, and pics of the scratches later tonight.
You can also contact me on my aim....... AIM = Beckingtonsays
or call me 716-725-7027.
Modified by Beckington at 2:04 PM 11/11/2006
Exterior:
Foglights
Undercoated
Interior:
Trust Shift ****
Reverse Gauges
Power Locks
HKS Turbo Timer
JDM Center Counsel
Suspension/Brakes:
Front sway bar
Brembo Blanks
Engine:
D16A6 block
Z6 head
Eagle Rods
2.5" Down Pipe
2.5" Exhaust
2.25" Charge Pipe
1g DSM BOV
DSM Injectors
Tuned with Crome
New Battery
NGK Spark Plugs
ACT Clutch
Lightened Flywheel
The Bad:
Onto the pics:
bump for my cars alter ego..... i have a crx plus some cash for trade.... mint 88 crx si. if my eg ever sells i would consider yours for purchase...
heres a link to my eg:
https://honda-tech.com/zerothread?id=1791821
and here is a pic of my crx:
bummmp
idle problem is fixed, and i just got this installed 300 miles ago...
Exedy 3 puck ceramic clutch with double fingered pressure plate (good for 400whp) and a 6.5 lb Fidanza Flywheel with replaceable surface.
KyoCivic98
Mar 27, 2011 08:52 AM
christhereefer
Feb 19, 2009 01:49 PM
