tire size for slammed dc2
Old Nov 11, 2006 | 02:16 AM
leinadmiih00's Avatar
Default tire size for slammed dc2
what a good tire size i should run with 15" rims on my dc2? and the car is slammed
Old Nov 11, 2006 | 11:16 AM
FalkenSiR's Avatar
Default Re: tire size for slammed dc2 (h22a4sh)
195-50/15 is the standard/most popular tire. However there are 195-45/15s that a few companies make.
Post pics of the allegedly slammed car.
Old Nov 11, 2006 | 11:54 AM
i dont have pics yet. but can i run 205/50?
Old Nov 11, 2006 | 02:17 PM
vtecsi00's Avatar
Default Re: (h22a4sh)
195/50r15
Old Nov 16, 2006 | 03:25 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: (vtecsi00)
195/50-15 is too small for a DC2, even for a lowered car.
Get 195/55-15 or 205/50-15. Either size will work fine.
Old Nov 30, 2006 | 08:30 PM
HONDA RR's Avatar
Default Re: (nsxtasy)
195/50/15
Old Nov 30, 2006 | 09:02 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: (HONDA RR)
Old Dec 1, 2006 | 02:13 PM
FalkenSiR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxtasy &raquo;</TD></TR><TR><TD CLASS="quote">
Most people that have "slammed cars" rub with 205s or 55 profile tires. Check the slammed thread. 195-50/15 is not the correct size for the car, and it will throw the speedometer off, but nothing too noticeable either.
I would give up speedometer accuracy by a couple miles for not rubbing at every turn
Old Dec 1, 2006 | 05:07 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: (J.MONEY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J.MONEY &raquo;</TD></TR><TR><TD CLASS="quote">Most people that have "slammed cars" rub with 205s or 55 profile tires.</TD></TR></TABLE>
Are you talking about EG and older Civics, or Integras? Because Integras don't rub with 205/50-15 or 195/55-15. I know a lot of people with lowered Integras with 205/50-15 or 195/55-15 tires, including ITRs (which are already 15 mm lower than other Integras), some of them really slammed, and none of them have rubbing problems.
205/50-15 and 195/55-15 both work fine on Integras such as the DC2 of the original poster above. There's no need to get the undersized 195/50-15 for an Integra. However, 195/50-15 is the proper 15" size for all CRXs, del sols, and pre-'96 Civics like yours; maybe those are the "slammed cars" you're thinking of as rubbing with the larger sizes. Remember, Integras are designed to use larger tires than pre-'96 Civics and CRXs.
Old Dec 1, 2006 | 11:01 PM
invisible's Avatar
What's the proper size for 96-00 Civic's? Anything wrong with using 195/50/15 on those?
Old Dec 2, 2006 | 08:10 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: (Battle23)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Battle23 &raquo;</TD></TR><TR><TD CLASS="quote">What's the proper size for 96-00 Civic's?</TD></TR></TABLE>
For '96 hatchback and DX models only: 195/50-15.
For all '97-00 Civics and all other '96 Civics: 195/55-15 or 205/50-15.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Battle23 &raquo;</TD></TR><TR><TD CLASS="quote">Anything wrong with using 195/50/15 on those?</TD></TR></TABLE>
Your speedometer and odometer will be off by over 3 percent. Just stick with the proper size for your car.
Old Dec 2, 2006 | 03:04 PM
Leo C's Avatar
Night Owl
Default Re: tire size for slammed dc2 (J.MONEY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J.MONEY &raquo;</TD></TR><TR><TD CLASS="quote">195-50/15 is the standard/most popular tire. However there are 195-45/15s that a few companies make.
Post pics of the allegedly slammed car.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecsi00 &raquo;</TD></TR><TR><TD CLASS="quote">195/50r15 </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HONDA RR &raquo;</TD></TR><TR><TD CLASS="quote">195/50/15 </TD></TR></TABLE>
Are you guys joking? I've accidentally ran a 195/50/15 on a DC2 and it was a big sacrifice of ride quality, made the car looks ridiculous as well.
OP: 205/50/15 is my personal recommendation, however 195/55/15 will work as well. Don't buy 195/50/15
Old Dec 3, 2006 | 09:39 AM
DFW's Avatar
DFW
Default Re: tire size for slammed dc2 (Leo.C)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxtasy &raquo;</TD></TR><TR><TD CLASS="quote">For '96 hatchback and DX models only: 195/50-15.
Your speedometer and odometer will be off by over 3 percent. Just stick with the proper size for your car.</TD></TR></TABLE>
Why is it only 96 dx hatchback different from 96-98 or even 96-00?
Old Dec 3, 2006 | 10:41 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: tire size for slammed dc2 (DFW)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DFW &raquo;</TD></TR><TR><TD CLASS="quote">Why is it only 96 dx hatchback different from 96-98 or even 96-00?</TD></TR></TABLE>
Because the stock tire size is different.
For 1996, the following Civic models came with tire size 175/70-13 (outer diameter 22.65 inches):
CX Hatchback
DX Coupe
DX Hatchback
For these models, the best tire size (closest match to the stock outer diameter) is:
14" wheels - 185/60-14
15" wheels - 195/50-15
16" wheels - 205/40-16
For 1996, the following Civic models came with tire size 185/65-14 (outer diameter 23.47 inches):
EX Coupe
EX Sedan
HX Coupe
LX Sedan
14" wheels - 185/65-14 (can also use 195/60-14)
15" wheels - 195/55-15 (can also use 205/50-15)
16" wheels - 205/45-16 (can also use 215/45-16)
Beginning in 1997, no Civics came with 175/70-13 tires; all Civics came with 185/65-14 or larger.
Old Dec 3, 2006 | 10:52 AM
DFW's Avatar
DFW
Default Re: tire size for slammed dc2 (nsxtasy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxtasy &raquo;</TD></TR><TR><TD CLASS="quote">Because the stock tire size is different.
CX Hatchback
DX Coupe
DX Hatchback
So 195/50/15 goes for only in 96 in those models above or those models for 96-00?
Old Dec 3, 2006 | 01:33 PM
nsxtasy's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DFW &raquo;</TD></TR><TR><TD CLASS="quote">So 195/50/15 goes for only in 96 in those models above or those models for 96-00?</TD></TR></TABLE>
<u>195/50/15 for</u>:
all pre-'96 Civics
'96 CX Hatchback
'96 DX Coupe
'96 DX Hatchback
<u>195/55-15 or 205/50-15 for</u>:
all '97-00 Civics
'96 EX Coupe
'96 EX Sedan
'96 HX Coupe
'96 LX Sedan
Old Dec 3, 2006 | 11:01 PM
leroy06's Avatar
Old Dec 4, 2006 | 12:26 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: (leroy06)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by leroy06 &raquo;</TD></TR><TR><TD CLASS="quote">195/50/15</TD></TR></TABLE>
Fat Chick Magnet
Jul 4, 2008 05:50 AM
xasiansupermanx
Feb 20, 2008 08:07 AM
xionl1350
Oct 30, 2006 06:59 PM
SumOne
17
Mar 13, 2006 01:30 PM
SuperTomcat
Aug 15, 2005 09:16 AM
