Building Turbo Dart, Mahle Pistons, Pauter Rods, Eagle Crank
Old Nov 10, 2006 | 10:17 PM
DavidCivicSi's Avatar
Default Building Turbo Dart, Mahle Pistons, Pauter Rods, Eagle Crank
My new project is 226mm Turbo Dart Block, and i want to know if my setup will work.
This is my list of parts :
1. 226mm Dart Block with 84.5mm bore.
2. Mahle Pistons 84.5mm bore 9.0:1 comp.
3. Pauter Rods.
4. Eagle 95mm stroker 4340 Crank.
5. EK4 B16A Head with Crower stuff.
what do you think guys ?!
Old Nov 10, 2006 | 10:33 PM
Schister66's Avatar
Man U FTW
is this where we're supposed to be all impressed or did you have a question???
Old Nov 10, 2006 | 10:37 PM
quik sol's Avatar
Default Re: (Schister66)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schister66 &raquo;</TD></TR><TR><TD CLASS="quote">is this where we're supposed to be all impressed or did you have a question???</TD></TR></TABLE>
shut the .... up...god, people like you ruin this forum...
anyways, I am not to sure with the stroke crank, so I will let someone else answer if that will work or not...
don't mind the e-thug newbs on this forum...
Old Nov 11, 2006 | 12:12 AM
miller's Avatar
Default Re: (quik sol)
it sounds like a bunch of money spent in the wrong places to me.
Old Nov 11, 2006 | 03:15 AM
DaveF's Avatar
Default Re: (miller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by miller &raquo;</TD></TR><TR><TD CLASS="quote">it sounds like a bunch of money spent in the wrong places to me.</TD></TR></TABLE>
same here..
stock block/crank works fine for us.
Old Nov 11, 2006 | 07:27 AM
b18sihatch's Avatar
Default Re: Building Turbo Dart, Mahle Pistons, Pauter Rods, Eagle Crank (DavidCivicSi)
question is what does your turbo kit look like?
a block power worth is only as good as the turbo kit making the power!
if you are running something like a full race turbo kit with that block
Old Nov 11, 2006 | 09:45 AM
Schister66's Avatar
Man U FTW
ok then here's the answer you were looking for i guess.....
yes your parts will work but what are you using for a turbo setup? what does your fuel system consist of? Clutch? Tranny? etc....
Old Nov 11, 2006 | 09:54 AM
quicksilver1689's Avatar
i ♥ snails
84.5X 95mm wow should have nice torque
Old Nov 11, 2006 | 11:21 AM
earl's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by miller &raquo;</TD></TR><TR><TD CLASS="quote">it sounds like a bunch of money spent in the wrong places to me.</TD></TR></TABLE>agreed
Old Nov 11, 2006 | 01:13 PM
quik sol's Avatar
just cause the average turbo honda person doesn't use a stroker doesn't mean it's not money well spent...he is just going outside the box.
Old Nov 11, 2006 | 04:43 PM
TurboJesse
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quik sol &raquo;</TD></TR><TR><TD CLASS="quote">just cause the average turbo honda person doesn't use a stroker doesn't mean it's not money well spent...he is just going outside the box.</TD></TR></TABLE>
what happens when the crank breaks...litterally
Theres a difference with thinking outside the box and unnecessary ****
Old Nov 11, 2006 | 05:24 PM
miller's Avatar
Default Re: (TurboJesse)
Do as you wish is all im gonna say, when you break that POS crank and have a leaky headgasket cause of that POS block your gonna kick yourself.
That man is not in any way shape or form of thinking outside the box, you must know how to realize what is in the box to think outside of it and Do as you wish.
Old Nov 11, 2006 | 05:25 PM
miller's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboJesse &raquo;</TD></TR><TR><TD CLASS="quote">what happens when the crank breaks...litterally
Theres a difference with thinking outside the box and unnecessary **** </TD></TR></TABLE>
exactly
Old Nov 11, 2006 | 05:47 PM
pgmatt's Avatar
Have people had problems with Eagles Honda cranks?What is wrong with Darts block?Just asking i have no experience with either.
Old Nov 11, 2006 | 06:29 PM
quik sol's Avatar
eagle isn't as bad as everyone says...
Old Nov 11, 2006 | 06:30 PM
TurboJesse
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quik sol &raquo;</TD></TR><TR><TD CLASS="quote">eagle isn't as bad as everyone says...</TD></TR></TABLE>
do you have personal experience?
i have seen 2 broken cranks personally and there was just a post last week or so about someones 95mm crank breaking in half...
i'd run their rods if i was on a budget but wouldn't run a crank if someone gave it to me.
Old Nov 11, 2006 | 06:31 PM
miller's Avatar
how many engines have you built with eagle cranks?
Old Nov 11, 2006 | 06:35 PM
B18C1CYA's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by miller &raquo;</TD></TR><TR><TD CLASS="quote">Do as you wish is all im gonna say, when you break that POS crank and have a leaky headgasket cause of that POS block your gonna kick yourself.
That man is not in any way shape or form of thinking outside the box, you must know how to realize what is in the box to think outside of it and Do as you wish.</TD></TR></TABLE>
I have seen the cranks bust also , but what is bad on the dart blocks ??? I have had mine for over a year now , do they have problems with headgaskets ?
Old Nov 11, 2006 | 06:36 PM
quik sol's Avatar
no, miller just likes to hate on everyone from what I have noticed...
Old Nov 11, 2006 | 06:39 PM
miller's Avatar
Default Re: (B18C1CYA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C1CYA &raquo;</TD></TR><TR><TD CLASS="quote">I have seen the cranks bust also , but what is bad on the dart blocks ??? I have had mine for over a year now , do they have problems with headgaskets ?</TD></TR></TABLE>
from my personal experience with using dart blocks i dont like them. They have some issues that need to be taken care of before i can ever justify the price to a customer. Its a very unfinished product
Old Nov 11, 2006 | 06:40 PM
miller's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quik sol &raquo;</TD></TR><TR><TD CLASS="quote">no, miller just likes to hate on everyone from what I have noticed...</TD></TR></TABLE>
who have i hated on ********? i tell it how it is and if you dont like please see sig below
Old Nov 11, 2006 | 06:48 PM
B18C1CYA's Avatar
what issues have you found ?? just would like to know if I should excpect any problems
Old Nov 11, 2006 | 06:55 PM
quik sol's Avatar
Whatever you say...
Old Nov 11, 2006 | 06:56 PM
miller's Avatar
I have had issues with the deck of the block not being correct, i have 2 instances with sleeve issues and the last one i did i had problems with the main alignment and had to do extensive maching to straighten it. these are all not major issues and were fixable with some time but i like i said earlier i ant justify the price for what you get.
miller's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quik sol &raquo;</TD></TR><TR><TD CLASS="quote">Whatever you say...</TD></TR></TABLE>
thank you
