suspension setup: tokico HP's with Eibach springs
Old Nov 10, 2006 | 01:14 PM
USDMSiR's Avatar
Default suspension setup: tokico HP's with Eibach springs
I was wondering if anyone was using this combo. i just put them on my crx w/b16 swap and the wheels rub a little and its mad slammed. i was going to get into auto x and it seems i cant with the rub. just wondering what you all are doing to negate this problem. thanks.
Old Nov 10, 2006 | 01:33 PM
Tyson's Avatar
Default Re: suspension setup: tokico HP's with Eibach springs (USDMSiR)
what wheel/tire are you using?
you can always jsut remove the inner fender liner if thats causing the rub.
and its not good for handling performance to be so low anyway.
and i dont ever recommend anyone buy tokico HP blues. its not worth the money. spend the extra on illuminas, the build quality is much better.
if you insist on running low, get extended top hats to regain your missing shock travel.
Old Nov 10, 2006 | 02:03 PM
USDMSiR's Avatar
Default Re: suspension setup: tokico HP's with Eibach springs (Tyson)
its not that i insist running low, the shocks arent adjustable so i kinda have to. lol. now there is a weird knocking whenever im off the throttle. it seems to knock once per rotation of the wheel. i can feel it on the pedals and it sounds like its hitting the floor.
Old Nov 10, 2006 | 02:11 PM
Tyson's Avatar
youve got a loose balljoint or loose lugnut or something. check your lugnuts at the least.
Old Nov 10, 2006 | 02:12 PM
USDMSiR's Avatar
aight. i will check it. im sick of working on it. i got 2 hours of sleep last night because i worked on that baisch. lol. thanks man. oh, and where would i find the extended bump stops. i would like at least .5" higher. the scraping is pissing me off. lol
Old Nov 10, 2006 | 02:13 PM
USDMSiR's Avatar
err top hats.
Old Nov 10, 2006 | 02:15 PM
Tyson's Avatar
top hats wont change your ride height. they just give you back some shock travel so you dont bottom out the shock.
actually i take it back. i just realized that you are running regular drop springs. it wont work quite well. its designed to be used with race springs, like on "coilovers". sorry about that.
maybe thats what you can do. is get some adjustable springs. then you can get the top hats.
Old Nov 10, 2006 | 02:17 PM
USDMSiR's Avatar
ahh, ok. well i guess im just going to have to put up with the scraping. lol. or get smaller tires. im running 205's right now.
Old Nov 10, 2006 | 02:23 PM
Tyson's Avatar
you can get springs with less of a drop...
Old Nov 10, 2006 | 03:04 PM
3s0n3's Avatar
205 what?
Old Nov 11, 2006 | 04:43 PM
USDMSiR's Avatar
Default Re: (3s0n3)
tire width. 205/50/15
luuisss
Suspension & Brakes
12
Jun 12, 2012 07:50 PM
1995Civiccx
Jan 28, 2007 08:24 AM
stackz
Mar 15, 2004 07:59 AM
erikiksaz1
Jan 7, 2004 11:56 PM
-K3-
Aug 20, 2002 06:22 PM
