How to tell if transmission fluid has been changed or not???????
Old Nov 10, 2006 | 01:14 PM
integracura's Avatar
Default How to tell if transmission fluid has been changed or not???????
I just got my transmission fluid drained and filled at the Honda Doctor, I just wanted to know how can i tell if they really did the job or not, cuz they finished like in 25 mins? I looked at the bolts from bottom and i saw that they were wet so i think they did it, but i dont feel the change in better shifting.
What else should i check?
Old Nov 10, 2006 | 01:25 PM
ck123's Avatar
if its red its clean, if its black its dirty
Old Nov 10, 2006 | 01:33 PM
what do u mean if what is red its clean, im not a expert on cars so...
Old Nov 10, 2006 | 01:48 PM
red01teg's Avatar
Default Re: (integracura)
He means to check your tranny dipstick. If the oil on it is red its clean..ifs its black its dirty.
Old Nov 10, 2006 | 01:54 PM
where is that located at? i have a manual transmission.
Old Nov 10, 2006 | 01:55 PM
HoUTX98GSR's Avatar
Default Re: (red01teg)
Noone has even asked him if its manual or auto...
Doesnt MTF look like oil? and ATF is red, right?
Old Nov 10, 2006 | 02:16 PM
does manual transmission even have a dipstick? if so, where?
Old Nov 10, 2006 | 03:22 PM
PogKai's Avatar
No disptick on manual. and yes tranny fluid can be changed that fast.. I work at a Honda dealer and I can change it in like 15 mins or so.
Old Nov 10, 2006 | 04:30 PM
Sam92Teg's Avatar
Default Re: (PogKai)
Pull your passenger side tire, find the fill hole on the side of the tranny, pull the plug and see if oil comes out. If it does, get a clean white towel and look at the condition of it. If it is clear and looks like fresh oil out of a bottle, then it was changed. I hope they used Honda MTF and not straight oil.
If you pull the fill bolt and oil doesn't come out, stick your finger in the hole and feel down a little to see how low the level is, it should be all the way up to the hole.
Old Nov 10, 2006 | 04:52 PM
Uncle Willie's Avatar
Default Re: (Sam92Teg)
****, i can do it in like 3 min at work. Fluid is almost NEVER very dirty. Youll almost never notice any change. Its always good to change it tho.
airikkCRX
Jul 2, 2010 11:49 PM
H_Accord
Feb 23, 2003 04:04 PM
professorman
Jan 12, 2003 06:40 AM
lonefuzzy79
Apr 30, 2002 07:51 PM
LshatchTurbo
Dec 15, 2001 03:34 PM
