Street Sleeper - GT28RS (SSAC) Is this turbo perfect?
Old Nov 10, 2006 | 01:10 PM
PINKS's Avatar
I want a CRX tattoed on my butt
Default Street Sleeper - GT28RS (SSAC) Is this turbo perfect?
Im going to be changing my turbo setup this coming season as I dont like my setup this year, just to much power and not the power band I want. I want to make a fun car to drive around on the street, that has power everywhere.
It will be going in a Crx, d16 motor with forged internals and some headwork. Capable of probably pushing the turbo to its limits, or atleast the dsm 450's. @ 15-18psi
http://cgi.ebay.com/ebaymotors...QrdZ1
Thats the turbo I want, its aparently ball bearing. Ive been searching on them on here and people say they spool incredibly quick but all those motors were b series and the actual garrett turbos. Not the SSAC knockoff's.
I also dont know much about the turbine sizing, some people were saying there was a .82 version made? What is this .60/.63 like?
Can anyone make any speculation on what the spool time will be like on a built d16 with VERY short charge piping via backdoor intercooler. Right now I dont see full boost til 5500 and it sucks.
Also, about the internal wastegate, I notice its mounted on the compressor housing, for the backdoor intercooler, Im going to have to clock that compressor housing so the outlet faces the front of the car and down. How would I mount the wastegate? Does it matter? I was hoping to keep it internally gated as I should be able to control it fairly easily right?
Looking for advise here
Old Nov 10, 2006 | 01:50 PM
beepy's Avatar
Default Re: Street Sleeper - GT28RS (SSAC) Is this turbo perfect? (PINKS)
I like to use the internal wastegate, too. You have to make a custom bracket and may have to make a custom link to get the wastegate to fit. This is how mine ended up:
Ignore the rust on the SSAC "stainless" V-band. It's still functional.
Old Nov 10, 2006 | 02:06 PM
shortyz21's Avatar
get a b series.
also your topics are a waste of space on honda tech.
Old Nov 10, 2006 | 02:15 PM
TheShodan's Avatar
Moderator
Default Re: Street Sleeper - GT28RS (shortyz21)
There are many solutions to this problem other than a GT28Rs. PM me if you'd like to look at other options that are within your range. please also tell me which flanging you want to use for the manifold and downpipe.
Old Nov 10, 2006 | 02:42 PM
nowtype's Avatar
Default Re: Street Sleeper - GT28RS (TheShodan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheShodan &raquo;</TD></TR><TR><TD CLASS="quote">There are many solutions to this problem other than a GT28Rs. PM me if you'd like to look at other options that are within your range. please also tell me which flanging you want to use for the manifold and downpipe.</TD></TR></TABLE>
Your posts are LOLtastic. I love them. Thank you.
OP: Get a GT28R. You should be able to score one used in the $500 range.
Old Nov 10, 2006 | 09:04 PM
PINKS's Avatar
Default Re: Street Sleeper - GT28RS (rota92)
Yeah I personally just want this car for the street so I dont need crazy numbers, I havent lost a race with my huge turbo yet, I just dont like how it drives, I dont like how small my powerband is
So I was thinking since Im bored anyways this winter, I might aswell build my own manifold/downpipe/backdoor intercooler setup with a cheap ($300 cheap) SSAC ball bearing turbo
Was wonderring what I could get/do with it and if ther internal wastegate was any good to somehow allow me to hold a 15-17psi range, even a way to mock it with me clocking the compressor housing
Old Nov 10, 2006 | 10:08 PM
93CX's Avatar
Default Re: Street Sleeper - GT28RS (PINKS)
If you're buying a turbo with the intentions of maxing it out, I cant see how a SSAC turbo would make any sense at all. Just get an authentic one.. and this is coming from the owner of a SSAC t3/t4
Old Nov 10, 2006 | 10:17 PM
PINKS's Avatar
Default Re: Street Sleeper - GT28RS (93CX)
No I will not be spending $1000 on a budget built car that I just like to have fun with
This is the turbo im interested in, as its cheap and seems to be perfect for a street ripper with great power all throughout the powerband, and I wouldnt have to wait for boost at all, no downshifting
Will I max it out @ 17psi? I dont know
Old Nov 10, 2006 | 10:40 PM
Schister66's Avatar
Man U FTW
you'll probably max it out before 17psi.....either the injector duty cycle will be maxxed (the hopeful outcome) or the turbo will break....
Old Nov 11, 2006 | 03:37 AM
PINKS's Avatar
Default Re: (Schister66)
I already maxed out my dsm injectors with my current turbo on 15psi but its much bigger, all I did to solve that was up fuel pressure
Does the housing size of this turbo listed in the ebay auction (.60/.63) seem to large?
Will it still spool ridiculously fast?
Old Nov 11, 2006 | 03:50 AM
Hondacivicnut's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schister66 &raquo;</TD></TR><TR><TD CLASS="quote">you'll probably max it out before 17psi.....either the injector duty cycle will be maxxed (the hopeful outcome) or the turbo will break....</TD></TR></TABLE>
As said above buy that turbo.I'm sure it will be smoking within a few thousand miles
Old Nov 11, 2006 | 07:01 AM
quicksilver1689's Avatar
i ♥ snails
Internal Wastegate @ 12 - 16 Psi
HP Rating UP TO 575
Hahaha since when do gt28's even remotely hit the 500hp mark.
spuddo01's Avatar
Default Re: (Hondacivicnut)
people say if you get ssac turbos just get them rebuilt and they will not break.
Old Nov 11, 2006 | 07:22 AM
b18sihatch's Avatar
Default Re: (spuddo01)
its better to just get a garrett turbo and forget about it
Old Nov 11, 2006 | 08:11 AM
Default Re: (b18sihatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18sihatch &raquo;</TD></TR><TR><TD CLASS="quote">its better to just get a garrett turbo and forget about it</TD></TR></TABLE>
Old Nov 11, 2006 | 08:16 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spuddo01 &raquo;</TD></TR><TR><TD CLASS="quote">people say if you get ssac turbos just get them rebuilt and they will not break.</TD></TR></TABLE>
Well I've had personal experience of this kinda junk.I had my SSAC T3 rebuilt twice.It kinda takes the **** after the second rebuild it starts smoking again.Pulled it apart & the genuine garrett bearings that were fitted were fine.The CHRA was worn giving shaft play of approx 1mm
Old Nov 11, 2006 | 08:21 AM
PINKS's Avatar
Im not asking about the integrity of the turbo. Im happy trying to use it
Im curious to know if that size turbo will be perfect for what Im trying to accomplish and if boost can be regulated RELIABLY to 17or so psi and how I would accomplish that with internal wastegate
This is just a budget fun build and Ive had no problems with SSAC turbos and a 1/16th restrictor so please no more comments on that
Old Nov 11, 2006 | 08:24 AM
b18sihatch's Avatar
Default Re: (PINKS)
but why not do it right the fisr time? its imminite it will blow no doubt, and given that you could get a cheaper garrett turbo and that would work and last much longer
you want great integrity for things not questionable. esp in mechanical parts
Old Nov 11, 2006 | 08:30 AM
PINKS's Avatar
I dont have $1000 to spend on a real garrett one, and as you can ee from this thread, I change ym setup due to bordem every year anyways. The SSAC turbo Im running right now took a season of daily driving no problem everyday.
Im just curious is this specific turbo I linked to will spool very quickly on my car
Old Nov 11, 2006 | 09:41 AM
Schister66's Avatar
Man U FTW
during my first build i tried to save money and cut corners at times, but in the end i replaced everything i half-assed and now on my new build, i just saved up enough to do everything right the first time...
Old Nov 11, 2006 | 10:42 AM
JDMRice's Avatar
I now a couple guys running the ss turbos without any problems
Old Nov 11, 2006 | 10:46 AM
abnaasefmb's Avatar
Default Re: (quicksilver1689)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quicksilver1689 &raquo;</TD></TR><TR><TD CLASS="quote">Internal Wastegate @ 12 - 16 Psi
HP Rating UP TO 575
Hahaha since when do gt28's even remotely hit the 500hp mark.</TD></TR></TABLE>
not even 400 but more than most people give it credit for:
rmcdaniels
"I ran one for a while, it responded insanely quickly. The clutch was slipping on this session, got it fixed and made over 380 later on a built B16 at around 23 PSI:"
Old Nov 11, 2006 | 11:08 AM
PINKS's Avatar
Default Re: (abnaasefmb)
Seems to spool a bit late on that dyno graph doesnt it?
Any ideas on if the internal wastegate will actually hold the 16psi reliably?
Old Nov 11, 2006 | 11:19 AM
abnaasefmb's Avatar
Default Re: (PINKS)
8:1 cr
Old Nov 11, 2006 | 11:50 AM
nateg's Avatar
Default Re: (PINKS)
i might try one of those as well, you people need to realize that your almighty t3's have been basicaly the same since they were first produced yeah thats right their design is older than vtakkk,the gt28rs was designed around a sentra with a sr20de, garrets engeineers redesined the compressor and turbine wheels to let it spool and let the turbine flow, it spools like an srt-4, but can flow way more exaust,look into it on a 16 with stock compression you should be around 8-12 psi at 3500 rpm with the 60-63 size
quick question, can anyone say the name of that very lucky sentra?
