bleeding brakes
Old Nov 10, 2006 | 12:29 PM
oakpwr's Avatar
Default bleeding brakes
Do you have to bleed the brakes after changing the front pads even though you didn't disconnect the brake line?
I changed out the pads/rotors in my 89 crx today using this site: http://www.ntpog.org/mods/four...shtml
it was easier than what i expected from the helms manual and took me a half hour once i had the tools. the mechanic wanted 200$. what a rip off.
Old Nov 10, 2006 | 12:31 PM
Hond@'s Avatar
Default Re: bleeding brakes (oakpwr)
no you dont have to bleed the brakes but it might be a good idea if you havent yet
Old Nov 10, 2006 | 12:39 PM
gp70hs's Avatar
No, you typically don't need to, if all you replaced was the pads. I would recomend you check your brake fluid level, after you press the brake pedal, several times. If you didn't get the rotors turned, you should go easy on your brakes, so the pads will seat properly. The shop price probably included turning the rotor's, but if the rotor's are straight, turning them just makes them seat, immediately, instead of seating with a little use.
Old Nov 10, 2006 | 12:46 PM
Tyson's Avatar
yes you should.
its part of brake maintenance.
have you guys ever seen an old brake piston? all those pits and corrosion and what not make for an uneven surface that passes through the piston seal. if you went from fully extended piston, and pushed it back in, you could very easily be allowing air and other contaminants in the caliper.
bleed the brakes.
jjohn6438
Honda Civic (2001 - 2005)
32
May 11, 2009 05:43 PM
Kendo88
Mar 10, 2009 09:57 PM
elcid
Jul 25, 2008 11:04 AM
ishootpewpew
Nov 14, 2006 10:15 PM
digital sol
Oct 31, 2004 02:31 PM
