just recieved ground control coilovers but..
Old May 7, 2002 | 03:12 PM
Integra187's Avatar
Default just recieved ground control coilovers but..
i just recieved my ground control coilovers for koni shocks. I thought there is suppose to be a certain adapter so the item can be used with koni shocks. IN the box there is a black rubber thing, springs, coilovers sleeve and the adjustment **** around it. Is the coilovers suppose to be specially desinged or am i missing an item. Thanks.
Old May 7, 2002 | 03:18 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: just recieved ground control coilovers but.. (Integra187)
You sure you specified GC's for Koni shocks when you ordered? Where did you buy them from? I believe there is supposed to be a piece that sits on that c-clip on the shock body instead of the spring perch, and then the sleeve sits on that piece.
Old May 7, 2002 | 03:55 PM
Integra187's Avatar
Default Re: just recieved ground control coilovers but.. (PatrickGSR94)
i ordered them straight from ground control. On the box is says for koni. I may have to give them a call i guess.
Old May 7, 2002 | 05:29 PM
D.Lansing's Avatar
At least with the bilsteins, the "adapter" is a silver metal collar inside of the red anodized sleeve. Dunno if the konis are the same way but might want to look for a silver ring on the inside of your sleeves.
Old May 7, 2002 | 06:48 PM
HondaJon's Avatar
Default Re: just recieved ground control coilovers but.. (D.Lansing)
The "adapter" is in fact part of the sleeve itself. It is the black metal ring inside the base of the sleeve. This ring allows the sleeve to come to rest on the locking O-Ring on the Koni Yellow shocks. There is really no seperate "adapter" piece that you will be looking for in the box, it is part of the coilover sleeve itself, so just go ahead and slap those things on there, you will love them.
If you have any questions about the install, send an IM my way,
Jon
Old May 7, 2002 | 06:50 PM
ebelp's Avatar
Default Re: just recieved ground control coilovers but.. (HondaJon)
Is any sort of "adapter" needed if you're pairing GC coilovers with AGX struts?
Old May 8, 2002 | 05:57 AM
Community Builder
Default Re: just recieved ground control coilovers but.. (ebelp)
nope, just buy the regular GC sleeves.
Old May 8, 2002 | 08:00 AM
Integra187's Avatar
Jon
i just took a look and saw the black ring. Thanks.
Old May 12, 2002 | 07:58 AM
integra-modder's Avatar
have you installed them? what rates did you get?
acccord02se
Suspension & Brakes
Aug 11, 2009 01:54 PM
t0kyoStatus
Apr 15, 2008 12:13 AM
spooledu24
Apr 5, 2005 12:03 PM
sslude
May 25, 2003 11:06 PM
Rob!
15
Dec 22, 2001 02:05 AM
