Wiseco 81mm GSR piston rings?
Old Nov 10, 2006 | 11:09 AM
boostincoupe's Avatar
From: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
Default Wiseco 81mm GSR piston rings?
I might be picking up a used set of Wiseco pistons, and they need new piston rings.
Do I have to order replacement rings from Wiseco, or do I have other options (Nippon, JE, Total Seal, etc.)? How much do they run, and who are some good sellers for them?
Old Nov 10, 2006 | 11:24 AM
Default Re: Wiseco 81mm GSR piston rings? (boostincoupe)
Alright, I just won the auction for $66 shipped
So I need:
- Piston rings for at least 2 of the pistons
- Possibly one new piston (which would come with rings anyways)
Old Nov 10, 2006 | 11:35 AM
Mugencrxsir1's Avatar
I'd get new piston rings, just to be on the safe side. I recently one a used set of SRP pistons off ebay, and buy new rings just to be safe. But the seller told me the rings were used, so I had no choice.
Old Nov 10, 2006 | 12:52 PM
Default Re: Wiseco 81mm GSR piston rings? (Mugencrxsir1)
bump
Old Nov 10, 2006 | 02:28 PM
drintegra's Avatar
bump for you also interested
Old Nov 10, 2006 | 04:04 PM
PrecisionH23a's Avatar
You must run new rings on all of the pistons. Re-using rings is a very bad idea and is not recommended.
Any piston dealer can supply you with rings, drop me a PM if you need help. Whatever you run, don't run total seal. I am not a fan of those at all.
Old Nov 10, 2006 | 07:53 PM
bigbadboy's Avatar
any would know wat to get the gaps at for the SRP'S??
ziurek filmus
Apr 16, 2017 10:17 PM
rocket_R
Jun 13, 2006 11:09 PM
the g2 teg
Apr 25, 2006 01:30 PM
crex23
Feb 2, 2006 05:41 PM
