msd sucks
Old Nov 10, 2006 | 01:37 AM
boosted_slow's Avatar
Default msd sucks
i just got my swap in and put the msd distrubeter on made it 21 miles sheered the pin in it off put a stock gsr obd1 distrubeter in and now getting code 8 tdc can any let know if they have had this problem msd distrubeter is obd2 with a jumper harness to obd1 motor b16 had no code at idel with ether distrubeter only when im going with the stock gsr one timming is on say three out of 4 pully rotations on the 4th one its on the white mark is there a defreance from gsr to b16 the only thing i can think is the crank alingment senser is not in the msd dist.
Old Nov 10, 2006 | 07:39 AM
teal_dx's Avatar
Default Re: msd sucks (dznuts)
Thats a long sentence bro....
I've heard of the older MSD dizzy's doing that though.
Old Nov 11, 2006 | 01:15 PM
Default Re: msd sucks (teal_dx)
i just bought it. i found out why the tdc code, the ecu i bought has a crapy ebay chip in it and has a timming advaces in it at 1900rpms thats why it wasnt throughing the code till 1900r's the msd distrubeter doesnt have a crank alingment senser in it.
Old Nov 11, 2006 | 01:31 PM
THE GUY's Avatar
Not to be confused with "THE MAN"
If the dizzy is for a OBD2 motor it does not have a crank angle sensor as you stated. OBD2 B series have it on the oil pump, Runs off of a pick up gear behind the crank gear.
Could you just put a OBD2 pump on it and use the CYP sensor from that and run the wires to the ECU so it gets the correct signal?
psst......spell check
91h22cb7lx
Jul 14, 2007 02:08 PM
sinister357
Jun 5, 2005 09:02 PM
hybridnorth
Jul 10, 2003 11:53 PM
