hey i need your help if u can
Old Nov 9, 2006 | 09:59 PM
bigluelok's Avatar
Default hey i need your help if u can
my 88 civic hatch is messen up it cuts of wen hit the breaks or wants to cut of can someone please help me i need it
thanks alot for the help
Old Nov 9, 2006 | 11:42 PM
limpy's Avatar
Default Re: hey i need your help if u can (bigluelok)
uhhh... in english please, meaning what exactally is the problem?
Old Nov 10, 2006 | 06:45 AM
bigluelok's Avatar
Default Re: hey i need your help if u can (limpy)
its like when i push the break the car cuts off
Old Nov 10, 2006 | 07:19 AM
90b20vteckidd's Avatar
look for a short somewhere that is "brake" related. i would start with the wiring to your tail light bulbs
Old Nov 13, 2006 | 05:19 AM
limpy's Avatar
Default Re: (90b20vteckidd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90b20vteckidd &raquo;</TD></TR><TR><TD CLASS="quote">look for a short somewhere that is "brake" related. i would start with the wiring to your tail light bulbs</TD></TR></TABLE>
i would also think that it could somehow be vacume related... maybee the brake booster is taking up too much of the vacume pessure and stalling the engine. anywho have you done any mods to anything and then this started happening or one day it just started?
Old Nov 17, 2006 | 07:51 PM
bigluelok's Avatar
Default Re: (limpy)
no thats how i got it everthing is stock and i dont know wut it is i took it to a shop so they could check it out and theystill havent found anything and its been about a week
Old Nov 17, 2006 | 07:59 PM
SIred91's Avatar
Rainman
Default Re: (bigluelok)
check your battery cables for corrosion inside. Especially in the positive one, if its corroded then it sends a corrupt signal to the ecu every time there is a change in current, like when the brakes are pushed or the turn signal or the climate control.
I had the same issue with my 91 prelude and every time I would use anything while the car was running in motion it would die. It was corrosion inside the battery cables.
Old Nov 26, 2006 | 11:09 AM
bigluelok's Avatar
Default Re: (SIred91)
hey do u think it could be the injectors cuz its an older model and has EFI cuz they changed the map sencer
slammed ej8
24
Jan 7, 2010 02:53 PM
boostedblkef
12
Aug 9, 2006 05:56 PM
JSJ EG6
Oct 21, 2004 05:30 PM
Mr. Vapor
Dec 7, 2002 12:50 AM
REDBARON
Aug 27, 2002 06:54 PM
