Throwout bearing question..
Old Nov 9, 2006 | 09:08 PM
94preludeguy's Avatar
Default Throwout bearing question..
My throwout bearing makes an annoying squeek noise when the clutch is not engaged. I've been told by a few people that I could possibly adjust my clutch pedal to get it to go away. It only squeeks when it is disengaged but if it's pressed in barely an inch worth, it stops for the most part.
I'm replacing the clutch once I get my turbo installed anyways but I was just wondering if I could temporary fix this.
Old Nov 9, 2006 | 09:11 PM
ilovemydc5's Avatar
Default Re: Throwout bearing question.. (94preludeguy)
just go get another one true forgot about that, thanks for the pick me up guy wow u called me an idiot well this idiot knows how to bleed a clutch unlike like, wow watch out high preformance **** talker. u can run u little mouth all u want to i made a mistake good god. get a life an stop being a e-thug when in real life ur just a joke to this world that runs his mouth an knows he cant back himself up.
Modified by 96Accordh22 at 11:09 PM 11/9/2006
Old Nov 9, 2006 | 09:14 PM
hella_usdm's Avatar
Default Re: Throwout bearing question.. (96Accordh22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96Accordh22 &raquo;</TD></TR><TR><TD CLASS="quote">just go get another one</TD></TR></TABLE>
^^wow
the throwout bearing will only make noise when its engauged. The throwout bearing is what presses against the pressure plate "fingers" and disengauges the clutch. When your foot is off the clutch pedal the bearing is not spinning. Try bleeding your clutch.
Modified by hella_usdm at 10:38 PM 11/9/2006
Old Nov 9, 2006 | 09:22 PM
TheWalrus's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96Accordh22 &raquo;</TD></TR><TR><TD CLASS="quote">just go get another one true forgot about that, thanks for the pick me up guy </TD></TR></TABLE>
brilliant.
its usually the pilot bearing making noise when the clutch is engaged, since the TB isnt doing anything. but you could try adjusting the pedal...theres a pushrod on the pedal that sticks into the master cylinder, if theres no clearance b/w the rod and cyl, the tb will be held against the pressure plate fingers with the clutch engaged
Old Nov 9, 2006 | 09:46 PM
Wow that guy is an idiot.. Too bad you have to remove the entire transmission just to get to the damn thing, which I'll replace when I get a new clutch.. 100k on an OEM clutch...
Thanks for the help to everyone else. I don't know how to bleed a clutch but it's pretty common sense in the automotive world. I'm sure my dad knows how.
Old Nov 9, 2006 | 10:26 PM
TheWalrus's Avatar
bleeding the clutch wont help...that would keep the clutch from disengaging and would make it hard to get into all gears
TOAB
May 21, 2007 04:31 PM
NguyenEngineering
Jan 31, 2007 05:42 AM
si_hatch
11
Aug 9, 2005 09:05 AM
Typical Lucas
12
Jan 29, 2003 12:28 PM
95GS-R
Jan 18, 2002 01:22 PM
