NEED HELP!!!! Vibration When I Accelarate???
Old Nov 9, 2006 | 05:16 PM
coolguy660's Avatar
Default NEED HELP!!!! Vibration When I Accelarate???
Just recently my car has been vibrating really bad when I step on the gas. Some people told me it could be my axles or that I need the HUB CENTRIC RINGS on my wheels.
I really dont know what it could be so if you guys have encountered this problem help me out and let me know what it could be.
Thanks-
Old Nov 9, 2006 | 07:00 PM
aaronISthrowed's Avatar
Default Re: NEED HELP!!!! Vibration When I Accelarate??? (coolguy660)
It might be the motor mounts, i think it can cause that problem. Anyone care to verify this?
Old Nov 9, 2006 | 07:23 PM
ejmatzell's Avatar
Default Re: NEED HELP!!!! Vibration When I Accelarate??? (aaronISthrowed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aaronISthrowed &raquo;</TD></TR><TR><TD CLASS="quote">It might be the motor mounts, i think it can cause that problem. Anyone care to verify this?</TD></TR></TABLE>
yes. a friend of mine with an integra had the same problem and thought it was a bad alignment, took it to the shop and found out his motor mounts were shot.
Old Nov 14, 2006 | 02:57 AM
coolguy660's Avatar
Thanks guys!
Any motor mounts you recommend?
Old Nov 14, 2006 | 06:49 AM
Sam92Teg's Avatar
Default Re: (coolguy660)
Check the mounts, but if they are fine, the inner joint of the axles can cause vibration while accelerating.
Old Nov 14, 2006 | 06:53 AM
Default Re: (Sam92Teg)
Im just sticking with OEM mounts, but make sure thats the problem before you replace them.
Old Nov 14, 2006 | 08:14 AM
Swiftstar's Avatar
thats weird. because i had the same problem last winter. But i live in Quebec. so it snows like Crazy here. and my DA was vibrating badly when i was on the highway. but it was just that snow and ice was stuck and frozen under my car, and some other places dunno where exactly. but ya, the result's were the same. Go figure
Old Nov 14, 2006 | 10:06 AM
Default Re: (Swiftstar)
So your car was vibarting from the stuck ice?
Old Nov 14, 2006 | 10:11 AM
dvp's Avatar
dvp
Default Re: (aaronISthrowed)
The only way it's from the wheels is if you have something stuck to them or one is badly out of balance.
Check the axels and do you have ES bushings??
Old Nov 15, 2006 | 02:53 AM
coolguy660's Avatar
Default Re: (dvp)
My mounts do need to be replaced. When I took it to the mechanic he said I should replace the mounts soon, but I didn't feel any vibrating then til now. So I'm sure it's the mounts.
OEM is the best way to go then?
How about the AVID mounts? Do those cut down on the motor vibrating?
19992civichatch
Jan 15, 2007 02:20 PM
Tonydalude
Nov 17, 2004 01:29 PM
Death_to_Thieves
Oct 28, 2004 04:42 PM
Rratedcivichatch
Jan 2, 2003 03:51 PM
