Short Shifter
Old Nov 9, 2006 | 04:39 PM
Djole_V's Avatar
Default Short Shifter
Oke i need some education and explantion if I buy a short shifter for my stock 96 civic coupe ex will the shifter fit later on in there future if i plan to buy a b18c engine?
Old Nov 9, 2006 | 06:38 PM
Djole_V's Avatar
Default Re: Short Shifter (Djole_V)
bump
Old Nov 9, 2006 | 06:40 PM
jllong95's Avatar
yes it will i have the same shifter since i bought the car now it has a lsvtec swap same shifter
Old Nov 9, 2006 | 06:54 PM
Djole_V's Avatar
Default Re: (jllong95)
if i buy the b and m does not matter all right thanks alot then?
Old Nov 9, 2006 | 07:29 PM
Libertariat's Avatar
Ek Forever y0!
Default Re: Short Shifter (ThatGuy4life)
B&M makes a good one if you have it, but I don't think the d series B&M will work for a b series.
Old Nov 9, 2006 | 07:43 PM
NSfit's Avatar
Default Re: Short Shifter (ek forever guy)
yeah it will work but id segguest a skunk 2 shifter, with their ****. it had a really good weight for smooth shifting
Old Nov 9, 2006 | 07:49 PM
Ek Forever y0!
Default Re: Short Shifter (NScivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NScivic &raquo;</TD></TR><TR><TD CLASS="quote">yeah it will work but id segguest a skunk 2 shifter, with their ****. it had a really good weight for smooth shifting</TD></TR></TABLE>
Word
Old Nov 9, 2006 | 08:02 PM
VRD^sam's Avatar
yes it will work...buy a d-series one and then later on the if your gonna swap a b-series in your car just use washer to space your shifter...
Old Nov 10, 2006 | 06:24 AM
Djole_V's Avatar
Default Re: Short Shifter (pho^k)
oke thanks alot guys just wanted to know that so no matter which opne i buy for this engine it will for on b series?
Old Nov 10, 2006 | 06:26 AM
B18C5-EH2's Avatar
Former Moderator
Loved
Integra shift linkage has a wider opening where the bottom of the shifter bolts to the linkage, so unless you get a short shifter that comes with a bearing spacer (I know Dc Sports ones I've purchased came with one) it will NOT work with Integra shift linkage.
The other way to get around it is sell the Integra linkages and buy 99-00 Civic Si linkages - bolts up to the tranny and is the exact same length, bends, etc. as Integra linkage, but with the exact same size opening for the bottom of the shifter as your stock D series linkage.
This is the gosphel truth on this matter.
Old Nov 10, 2006 | 09:34 AM
TurboTagTeam's Avatar
Default Re: Short Shifter (B18C5-EH2)
I have a 93 civic hatch with a b16a, ITR shift likage, and a B&M shifter made for a 95 integra. All B&M shifters work for 92 and up civics and integras.
Old Nov 10, 2006 | 09:52 AM
B18C5-EH2's Avatar
Former Moderator
Loved
Default Re: Short Shifter (TurboTagTeam)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboTagTeam &raquo;</TD></TR><TR><TD CLASS="quote">I have a 93 civic hatch with a b16a, ITR shift likage, and a B&M shifter made for a 95 integra. All B&M shifters work for 92 and up civics and integras.</TD></TR></TABLE>
So the B&M must be packaged with a spacer to accomodate the Integra linkage since the Integra linkage is definately wider than Civic linkage.
It does have a spacer, right?
Old Nov 10, 2006 | 12:26 PM
Yes it does.
Old Nov 10, 2006 | 01:34 PM
Djole_V's Avatar
Oke i still have a question I want to get a b and m short shifter what is the difference between the normal single bend and the dual bend and does it matter which one I get?
Old Nov 10, 2006 | 01:48 PM
4drgsr96's Avatar
bends do not really matter. the teg linkage is wider, i've got a buddy club shifter, nice and heavy. if for some reason you dont have a spacer you can always go the ghetto route and just tighten the fork around the shifter, youll bend the linkage but it wont break. you should just hold off on that though if youre really itchin for that swap though
Old Nov 10, 2006 | 01:53 PM
Djole_V's Avatar
Default Re: Short Shifter (4drhonda)
I know but what i meant is what is the difference between the single and dual bend and do I need to buy adapter for the car?
Old Nov 10, 2006 | 02:27 PM
B18C5-EH2's Avatar
Former Moderator
Loved
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Djole_V &raquo;</TD></TR><TR><TD CLASS="quote">Oke i still have a question I want to get a b and m short shifter what is the difference between the normal single bend and the dual bend and does it matter which one I get?</TD></TR></TABLE>
If the dual-bend one is for an Integra you need to make sure the bottom of it isn't as wide as the Integra linkage, or else it won't fit inside the more narrow Civic linkage. If it's narrow to begin with and needs a spacer to fit into the Integra linkage then buy it - IMO the dual bend ones feel better in terms of where the **** is in relation to the center console.
Old Nov 11, 2006 | 07:37 PM
stealth50k's Avatar
Yes, b and d series shifters are the same.
Old Nov 13, 2006 | 05:05 AM
B18C5-EH2's Avatar
Former Moderator
Loved
Default Re: Short Shifter (stealth50k)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stealth50k &raquo;</TD></TR><TR><TD CLASS="quote">Yes, b and d series shifters are the same.</TD></TR></TABLE>
<FONT SIZE="7">NO THEY ARE NOT!!!</FONT>
Did you even read the whole topic yet? You might have learned that Integra shifters have a wider bottom than the Civic shifters, and that the linkages are also different to accomodate the difference.
Hell all B series shifters are not even the same - 99-00 Civic Si uses the smaller bottom like the D series, while the Integras still have the wider bottom.
Old Nov 13, 2006 | 05:19 AM
sicones's Avatar
If you buy a skunk 2 shifter, it comes with a spacer so you can use it on a B or D series linkage
Old Nov 14, 2006 | 12:41 PM
boostedbigguy's Avatar
if you plan on swaping ir motor with a b18 or somthing like that the shifter is fine, but you will need to get different linkage
BILLisCHILL
Aug 16, 2006 06:05 AM
BILLisCHILL
Aug 15, 2006 01:11 PM
...civic...
Mar 15, 2006 02:37 PM
ProjectCD5
Feb 21, 2006 11:55 PM
hcivic99
11
Jan 2, 2005 08:47 PM
