Resistor box with OBD-1 injectors... throwing code 16 and won't start.
Old Nov 9, 2006 | 03:42 PM
92_VX_EG's Avatar
Default Resistor box with OBD-1 injectors... throwing code 16 and won't start.
My buddies car is throwing a code 16 which is causing it not to start and run. It's a 91 standard hatch with an OBD-0 LS swap. I found out yesterday that the previous owner wired OBD-1 injectors on it. It ran fine for over a year like this until my buddy dropped a valve and wiped the motor. We put another motor in the car. It still has the resistor box hooked up. In another post this guy told me that if you have a resistor box and OBD-1 injectors it can burn the ECU where it controls the injectors.
What should I do about the resistor box? Can I just unplug it from the clip or what? Should I just wire some OBD-0 injectors, I'm not trying to do that but I will if I have to. Just in case the ECU is fucked I have another one to put in the car. This car hasn't been running in over 3 monthes and any help will be greatly appreciated.
Old Nov 9, 2006 | 03:46 PM
Rywire's Avatar
Default Re: Resistor box with OBD-1 injectors... throwing code 16 and won't start. (92_VX_EG)
pmed, prob solved
Old Nov 9, 2006 | 04:06 PM
Tippyman's Avatar
The title says it all. OBD1 injectors don't use a resitor box.
But I guess that's what droppedcrxsi told you...
Old Nov 9, 2006 | 07:14 PM
hybridmiklo's Avatar
Default Re: (Tippyman)
you are the **** droppedcrx!!
Old Nov 13, 2006 | 10:27 PM
Rywire's Avatar
Default Re: (hybridmiklo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybridmiklo &raquo;</TD></TR><TR><TD CLASS="quote">you are the **** droppedcrx!! </TD></TR></TABLE>
LOL, thanks
Old Nov 14, 2006 | 02:08 PM
iheartteal's Avatar
quick question about this post.
Im doing a swap in my ef and i have a resistor box but do not know which injectors i have since i bought the motor seperate from the car i do not know if the injectors are obd1 or obd0. How can i tell so i dont have the same problem as 92_vx_eg
Old Nov 14, 2006 | 02:19 PM
janz3n's Avatar
Default Re: (RideroftheHonda)
well what kind/year is the engine you just bought. that would help.
Old Nov 14, 2006 | 11:26 PM
92_VX_EG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RideroftheHonda &raquo;</TD></TR><TR><TD CLASS="quote">quick question about this post.
Im doing a swap in my ef and i have a resistor box but do not know which injectors i have since i bought the motor seperate from the car i do not know if the injectors are obd1 or obd0. How can i tell so i dont have the same problem as 92_vx_eg</TD></TR></TABLE>
OBD-0 have tannish white and OBD-1's grey injector clips.
Old Nov 15, 2006 | 02:14 PM
iheartteal's Avatar
i dont know what year car the motor is from but i know i have tannish colored clips
Randysi
Apr 4, 2012 10:17 AM
surkitroller
Dec 29, 2009 12:58 PM
e jay one
Aug 6, 2005 02:48 PM
mr. Grind
Aug 15, 2004 12:13 PM
kur0ryu
Apr 26, 2004 05:05 PM
