Maximum Throttle Body Bore for the H22 Intake Manifold?
Old Nov 9, 2006 | 02:54 PM
BB6-213's Avatar
Default Maximum Throttle Body Bore for the H22 Intake Manifold?
Hey guys. I am planing on upgrading my throttle body here soon, and I am wondering what the very maximum bore that can be achieved on the stock H22 intake manifold? BTW, the manifold is gutted/ported etc, so please no "why are you using the stock manifold" questions. Thanks.
Old Nov 9, 2006 | 04:15 PM
alterdcreations's Avatar
Default Re: Maximum Throttle Body Bore for the H22 Intake Manifold? (BB6-213)
i got a 74 to match
Old Nov 9, 2006 | 04:33 PM
Rosko's Avatar
Default Re: Maximum Throttle Body Bore for the H22 Intake Manifold? (alterdcreations)
I've done 70 on a gutted manifold. could go a little bigger though.
Old Nov 9, 2006 | 10:57 PM
BB6-213's Avatar
so 80mm+ is out of the picture i guess
Old Nov 9, 2006 | 11:33 PM
redtop22's Avatar
keep in mind that bigger is not always better.
by having such a large TB without any sort of taper will significantly affect air flow velocity.
i'd suggest getting a tapered TB to find a compromise between air volume and velocity.
Old Nov 9, 2006 | 11:35 PM
Mykizism's Avatar
Default Re: (redtop22)
he's got a big turbo, thats all the air velocity he needs
Old Nov 10, 2006 | 01:47 AM
redtop22's Avatar
^ touche
Old Nov 10, 2006 | 06:32 AM
Phat8186's Avatar
I have an STR 70mm Tb matched to a 70mm intake mani port opening on my h22a4 which will be sucking in turbo air
Old Nov 10, 2006 | 04:31 PM
BB6-213's Avatar
I think I might just take a shot with the 80mm and see if I can make it work.
Old Nov 10, 2006 | 05:09 PM
Default Re: (BB6-213)
endyne make a idle valve relocator.
Old Nov 10, 2006 | 05:12 PM
mgags7's Avatar
you'll be able to get an 80 to fit....no problem...
**** some kid posted up a few weeks ago with an 80mm mounted to his mani that he didn't want....
Old Nov 10, 2006 | 09:04 PM
Rosko's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redtop22 &raquo;</TD></TR><TR><TD CLASS="quote">keep in mind that bigger is not always better.
i'd suggest getting a tapered TB to find a compromise between air volume and velocity.</TD></TR></TABLE>
I think the reason that they come tapered is so that you don't have to modify the manifold so much to get them to work. I really don't think velocity has anything to do with it , but I could be wrong. Afterall the stock ones are straight through and so are the bigger mustang ones correct?
I'd like to see an 80 on one though, that'd be huge. I have a sketch of the bolt pattern at home I suppose I could draw a cirlce in there and see how big it could be.
Old Nov 11, 2006 | 08:37 AM
BB6-213's Avatar
Cool guys, I will be making an adapter plate and welding it on and see if I can make the beast fit.
Old Nov 11, 2006 | 08:44 AM
h22 civic's Avatar
q45
Old Nov 11, 2006 | 09:28 AM
Rosko's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BB6-213 &raquo;</TD></TR><TR><TD CLASS="quote">Cool guys, I will be making an adapter plate and welding it on and see if I can make the beast fit.</TD></TR></TABLE>
ahh, well if you're welding it on then that shouldn't be a problem at all. I know if you use the boly on style the throttle bore gets pretty close to the bolts that hold the adapter on.
Old Nov 11, 2006 | 09:59 AM
BB6-213's Avatar
Default Re: (h22 civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22 civic &raquo;</TD></TR><TR><TD CLASS="quote">q45</TD></TR></TABLE>
yes sir.
dglassmyer
Dec 10, 2012 10:02 PM
alfaaay
Jul 13, 2005 01:07 AM
JDMH22accord95
May 7, 2004 07:17 PM
JDMH22accord95
May 6, 2004 05:55 PM
JforJonathan
10
Apr 10, 2004 12:15 PM
