90-91 cluster in 88-89 crx
Old Nov 9, 2006 | 12:03 PM
ant$missShift's Avatar
Default 90-91 cluster in 88-89 crx
hey guys. ive been sitting on this 90-91 si cluster for a year now to put in my 89 si crx and finally decided to do it..... i searched and cant find any info on how to do it. i know it plugs right in but the wiring/pinouts are diffrent. just seeing if anyone could help me out. ..thanks.
Old Nov 10, 2006 | 07:28 AM
Default Re: 90-91 cluster in 88-89 crx (sxeonerX)
???????? no one?
Old Nov 10, 2006 | 08:25 PM
TTT
Old Nov 11, 2006 | 08:22 PM
no?
Old Nov 11, 2006 | 09:14 PM
mike9571's Avatar
It wont work. 90-91 shape/wiring differs from 88-89.
this is how i know
http://www.ef-honda.com/ben/sicluster.php
Old Nov 12, 2006 | 08:51 AM
Default Re: 90-91 cluster in 88-89 crx (mike9571)
i dont think its impossible.. i mean. if i have to get diffrent clips and rewire the whole thing its possible.. but i guess no one has done this?
Old Nov 12, 2006 | 09:12 AM
1QuikSOHCZC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike9571 &raquo;</TD></TR><TR><TD CLASS="quote">It wont work. 90-91 shape/wiring differs from 88-89.
this is how i know
http://www.ef-honda.com/ben/sicluster.php</TD></TR></TABLE>
it will work. you jus have to re-wire a couple wires and thats it. you will need a 90-91 cluster bezel(cover) to match the new cluster. there are articles on how to do it you jus need to search
Old Nov 13, 2006 | 01:45 PM
Default Re: 90-91 cluster in 88-89 crx (1QuikSOHCZC)
ive searched with no luck. all i got to come up was 88 89 into 90 91 and sir,da,and about a hundred other clusters.. ill try again tho. thanks.
Old Nov 13, 2006 | 02:33 PM
RPM_69's Avatar
Check the "CRX & Civic FAQ 2.0" topic near the top of the topics. There a few articles on swapping to Euro/teg gauges. I swapped my 89 CRX to the euro SiR gauges since I have a b18C1 w/ a 9.2K redline. The relevant articles are;
http://www.angelfire.com/ca/DrOhm/SiRcluster.html
https://honda-tech.com/zerothread?id=1732102
You should be able to piece together some of the info you need, but it will likely be incomplete. I eventully got fed up trying to find what I needed online, and just followed the circuit path on the cluster. It is really easy to follow and simply write down what light/gauge the pin goes to. I used a funny little hook-ended screw driver to press out the pins from the plug to move them around.
NOTE: Requires a cable driven speedo, and a 90+ gauge hood (bezel).
4DRmafia
15
Mar 19, 2007 02:56 PM
SloB16crxMike
May 11, 2006 04:11 PM
hypnotixcrx
Apr 28, 2005 12:04 PM
mbsi
Apr 6, 2003 11:54 AM
Hondasaurs
Feb 8, 2003 06:45 PM
