Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
thinks of putting a new flywheel and clutch
Old Nov 9, 2006 | 10:13 AM
spoonlongblock's Avatar
Default thinks of putting a new flywheel and clutch
I am think of puttinga new clutch and flywheel in this winter for next season. I want to put a Exedy lightweight flywheel in with one of their stage 1 clutches. My question will changing it have any adverse affects on my drivetrain and or the engine more importantly the DBW system. I don't think it will but wondering. It should give me better acceleration in place of top speed and maybe make 6th gear a little more bearable. Need some input??
Old Nov 9, 2006 | 10:17 AM
rbf351's Avatar
Default Re: thinks of putting a new flywheel and clutch (spoonlongblock)
how is your car going to accelerate better?
Old Nov 9, 2006 | 10:29 AM
Nighthawk R18's Avatar
if your going to adjust your gear ratios then yea it will give you acceleration and sacrifice top speed, depending on how u adjust.
Old Nov 9, 2006 | 10:38 AM
TRE_'s Avatar
Default Re: thinks of putting a new flywheel and clutch (Nighthawk R18)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nighthawk R18 &raquo;</TD></TR><TR><TD CLASS="quote">if your going to adjust your gear ratios then yea it will give you acceleration and sacrifice top speed, depending on how u adjust.</TD></TR></TABLE>
How are you going to "adjust" a gear ratio? without completley replacing a gear set/final drive there's no way to change gear ratios. An aftermarket/upgraded clutch in a STOCK vehice(even with bolt-ons) is not going to improve acceleration. a lighter flywheel will free up some rotational mass, allowing the motor to gain RPM more quickly, but its not going to improve accel..
basically unless youre current clutch is slipping from a substiantial HP gain(s/c / turbo), theres NO reason to change out the OE equipment... you will see ZERO gains in 0-60 or any sort of acceleration times.
why do you find 6th gear unbearable?
rbf351's Avatar
and since when does changing a clutch and flywheel change gear ratios?
Old Nov 9, 2006 | 10:42 AM
Default Re: thinks of putting a new flywheel and clutch (rbf351)
yea now that i think about it. sorry stupid post.
flame on
Old Nov 9, 2006 | 10:46 AM
Type X's Avatar
http://auto.howstuffworks.com/clutch.htm
Old Nov 9, 2006 | 01:00 PM
just wondering I had a friedn who had a crx with a b16 and stock flywheel and he said once he changed to a lighter flywheel the car seemed quicker
Old Nov 9, 2006 | 01:13 PM
Bighec1182's Avatar
Default Re: thinks of putting a new flywheel and clutch (TRE_)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TRE_ &raquo;</TD></TR><TR><TD CLASS="quote">
why do you find 6th gear unbearable?</TD></TR></TABLE>
+1, yea, what is so unbearable about 6th gear?
Old Nov 9, 2006 | 01:40 PM
Hellzcivic's Avatar
Default Re: thinks of putting a new flywheel and clutch (Bighec1182)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bighec1182 &raquo;</TD></TR><TR><TD CLASS="quote">
+1, yea, what is so unbearable about 6th gear?</TD></TR></TABLE>
I think the "unbearable" opinion stems from not acknowledging 6th gear is an overdrive, gas economy gear, not a performance, quick RPM gain gear. I guess if you want to scream up to red-line in every gear, 6th can feel a little "unbearable".
Even with the supercharger, unless I am at 6,000 RPM, the speed increase in 6th is not the quickest. Course, personally, 6,000 RPM is 6th means I am already going fast enough to make me **** my pants.
Btw, did you check out the Comptech Light weight flywheel and clutch assembly? I have been very happy with everything I have installed from Comptech. As soon as my factory clutch fails, I will be replacing mine with the Comptech set-up. The 60 fp increase in torque from the sc is hell on the factory clutch (or I suppose any clutch).
Modified by Hellzcivic at 2:52 PM 11/9/2006
Old Nov 9, 2006 | 08:03 PM
mInI m3 Hondeezy's Avatar
Default Re: thinks of putting a new flywheel and clutch (Hellzcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hellzcivic &raquo;</TD></TR><TR><TD CLASS="quote">
[/i]</TD></TR></TABLE>
Yep it evens says it in the manual. Only time u would actually need 6th is when your goin on the freeway.
Prelude Prince
Transmission & Drivetrain
Dec 8, 2016 10:05 PM
Falloutkid90
Dec 24, 2015 03:20 AM
Griff911
Honda Civic (2001 - 2005)
Sep 2, 2008 07:25 AM
migs
Jan 13, 2006 04:09 PM
preluder
Jun 24, 2003 07:00 AM
