Valve cover...tuning cam gears?
Old Nov 9, 2006 | 09:41 AM
B16b-EJ8's Avatar
Default Valve cover...tuning cam gears?
So im getting ready to upgrade my head and valve train and head to get the motor tuned. My question is where does one find a valve cover that shows the cam gears so that they cam be adjusted? unless im totally missing something the only way for the tuner to get to them would be to remove tha valve cover and this does not seem practical...so those of you who have been to the tuners to have cam gears dialed in and what not how does that work. I have never been to the tuner or on a dyno so im just curious. I finally have a build worth tuning.
Old Nov 9, 2006 | 09:45 AM
Padawan's Avatar
Darth ModerVader
Default Re: Valve cover...tuning cam gears? (B16b-EJ8)
My suggestion would be to buy a cheap used cover and cut it to expose the cam sprockets for tuning purposes. Then once the tuning is finished, you can reinstall your factory cover.
Old Nov 9, 2006 | 09:46 AM
B16b-EJ8's Avatar
Default Re: Valve cover...tuning cam gears? (Padawan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">My suggestion would be to buy a cheap used cover and cut it to expose the cam sprockets for tuning purposes. Then once the tuning is finished, you can reinstall your factory cover. </TD></TR></TABLE>
I figured that would be the case. Is that generally how its done
Old Nov 9, 2006 | 10:00 AM
Padawan's Avatar
Darth ModerVader
Well some people choose to cut their stock cover, but I don't favour that option because then it leaves the timing belt and cam sprockets exposed after the tuning is finished.
Old Nov 9, 2006 | 10:03 AM
B16b-EJ8's Avatar
Those were my thoughts on this...and getting a rock or so other piece of debri in there would not be a good idea. So in theory will any B series valve cover fir on any B series? I have a B16b so would i need one from like an si will any one work?
Old Nov 9, 2006 | 10:04 AM
B16b-EJ8's Avatar
where would one get it cut at? could i do this at home with a grinder and a skill say or something to that effect
Old Nov 9, 2006 | 10:08 AM
Padawan's Avatar
Darth ModerVader
Default Re: (B16b-EJ8)
Any B-series VTEC cover will work. You can definitely cut it yourself at home using any number of basic tools.
Old Nov 9, 2006 | 10:09 AM
B16b-EJ8's Avatar
Default Re: (Padawan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">Any B-series VTEC cover will work. You can definitely cut it yourself at home using any number of basic tools.</TD></TR></TABLE>
Thanks man
SoyMilk
Apr 6, 2007 11:34 AM
athoughts
Feb 5, 2005 09:06 AM
quicksol95
14
Apr 29, 2004 10:41 AM
Weel
Mar 17, 2004 05:01 PM
95IntegraGSRAZ
17
Jan 3, 2003 03:01 PM
