Fuel Rail/Pressure Regulator?
Old Nov 9, 2006 | 05:56 AM
ImPuLsIvE's Avatar
Default Fuel Rail/Pressure Regulator?
I'm looking to upgrade the OEM Fuel Rail and Fuel Pressure Regulator. However, I'm not sure which brand I should be going with.
I know AEM is very popular, but are there other companies I should be looking at that maybe make a better product?
Keep in mind this will be going on a built/forged/sleeved/P&P H22A4 engine designed for high (~20-30PSI) boost. So I need something good here.
Thanks!
Old Nov 9, 2006 | 06:35 AM
dreed2300's Avatar
Default Re: Fuel Rail/Pressure Regulator? (ImPuLsIvE)
I use the aem fuel rail and regulator on my turbo lude and it does a good job. If it is proven to work go with it.
Old Nov 9, 2006 | 07:37 AM
DMetal420's Avatar
Default Re: Fuel Rail/Pressure Regulator? (dreed2300)
OBX ftw!
Old Nov 9, 2006 | 07:53 AM
BB2H22's Avatar
Default Re: Fuel Rail/Pressure Regulator? (DMetal420)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DMetal420 &raquo;</TD></TR><TR><TD CLASS="quote">OBX ftw!</TD></TR></TABLE>
No.
Get AEM, their the best.. and its proven.
Old Nov 9, 2006 | 09:21 AM
ImPuLsIvE's Avatar
What about AC AutoTechnique? (spl?)
And is there any modification required to make this fit to the OEM fuel ports? Or is a straight forward process of taking the injectors our, swaping the rail and poping it all back in place? What about the Regulator?
Old Nov 9, 2006 | 09:35 AM
98vtec's Avatar
moderator emeritus
upgrading the fuel rail is pointless. I have one and wish i wouldnt have spent that 100+ dollars on it. however it does look good
MANY 500-600+whp honda's run a stock fuel rail.
FPR, i would go with Aeromotive.
Old Nov 9, 2006 | 10:02 AM
BB2H22's Avatar
The rail isnt very imortant but the FPR is.
Old Nov 9, 2006 | 10:10 AM
E-Money's Avatar
Default Re: Fuel Rail/Pressure Regulator? (98vtec)
Aeromotive work with stock fuel rail?
Old Nov 9, 2006 | 11:13 AM
BB2H22's Avatar
I know AEM will, not sure about aeromotive.
Old Nov 9, 2006 | 12:28 PM
king_me's Avatar
I haven't heard anything bad about BDL. then again I havn't heard anything good either
Old Nov 9, 2006 | 01:06 PM
Buffalo's Avatar
http://www.synapseengineering.com
Old Nov 9, 2006 | 04:39 PM
E-Money's Avatar
Default Re: (BB2H22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BB2H22 &raquo;</TD></TR><TR><TD CLASS="quote">I know AEM will, not sure about aeromotive.</TD></TR></TABLE>
Ive read on their sites that AEM FPR only works with their fuel rails..
Old Nov 10, 2006 | 05:57 AM
ImPuLsIvE's Avatar
Default Re: (E-Money)
What about AEM's universal FPR? Would that work on the OEM fuel Rail? What's required to make a FPR fit/work on the OEM rail? Isn't it easier to get an aftermarket rail?
That Synapse FPR looks fawkin nice! wow!
Old Nov 10, 2006 | 06:15 AM
v4lu3s's Avatar
RTFM
My vote goes to Aeromotive FPR.
Old Nov 10, 2006 | 07:14 AM
Greg H's Avatar
Default Re: (v4lu3s)
I have STR fuel rail and Aermotive Regulator.
Old Nov 10, 2006 | 07:37 AM
92blkJDMh22's Avatar
When i swapped in my H22a, i could not get the Golden Eagle to fit........ so i went with AEM and it worked just fine..... I have a B&M FPR and it bolted up fine to both the stock rail and the AEM rail.......
another advantage to having an aftermarket rail is that it makes it easy to hook up a Pressure Gauge
Old Nov 10, 2006 | 09:37 AM
PrecisionH23a's Avatar
Default Re: (92blkJDMh22)
The B&M regulator is **** and still uses the stock diaphram. Basically it is just a spring that increases pressure.
I've had 50/50 results with these units in conjunction to running the walbro HP fuel pumps. I would go AEM or Aeromotive
Old Nov 10, 2006 | 10:10 AM
98vtec's Avatar
moderator emeritus
Default Re: (PrecisionH23a)
i ahve heard about all these problems with the B&M but i have had mine for going on 5 years with no problems. But yes, it is very limited. You can only raise the fuel pressure.
Old Nov 10, 2006 | 06:06 PM
admiration's Avatar
I'd go with the AEM. I had both the FPR and the fuel rail on my H22 with no problems. Incidentally, I no longer need them and need to sell.
Old Nov 10, 2006 | 08:03 PM
y0whuddupb's Avatar
Default Re: (admiration)
AEM FPR and FR. do it right the first time!
carlos8
Nov 4, 2013 04:53 PM
drSquish
Feb 22, 2006 06:35 PM
chinners10
Jan 28, 2004 05:52 PM
typertn
Jan 9, 2004 11:58 PM
