ITR steering wheel in EG?
Old Nov 9, 2006 | 05:16 AM
rodvang's Avatar
Default Just wanted to make sure...
I was looking at the old posts but just wanted to make sure..USDM ITR Steering wheels will bolt directly into an eg correct?
Old Nov 9, 2006 | 05:45 AM
Statetrooper
Guest
Posts: n/a
Default Re: Just wanted to make sure... (rodvang)
exact fit.
Old Nov 9, 2006 | 07:36 AM
Stinkycheezmonky's Avatar
Suspetise...
Default Re: Just wanted to make sure... (Statetrooper)
Yep, bolt right up. Have one on my car temporarily, in fact.
Old Nov 9, 2006 | 09:42 AM
JDMbiAtcH's Avatar
Default Re: Just wanted to make sure... (Stinkycheezmonky)
direct fit
Old Nov 9, 2006 | 10:06 AM
92'si's Avatar
what about a jdm itr?
Old Nov 9, 2006 | 10:13 AM
rodvang's Avatar
Default Re: Just wanted to make sure... (92'si)
from what i was reading they fit also..but jdm ones are too pricey for me..haha
Old Nov 9, 2006 | 11:06 AM
BlueIntegraBoy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92’si &raquo;</TD></TR><TR><TD CLASS="quote">what about a jdm itr? </TD></TR></TABLE>
I have a JDM ITR non-srs in mine
Old Nov 9, 2006 | 11:15 AM
92'si's Avatar
Default Re: Just wanted to make sure... (BlueIntegraBoy)
well i would just rather have the "H" than the "A", i dunno why just like it better i guess
Old Nov 10, 2006 | 03:29 AM
Suspetise...
The only thing you'd need with a JDM ITR (at least the non-SRS one) is a little spacer between the wheel and the column. I used a pair of washers stuck together, and that worked fine.
Edit: Actually, some modification to the back of the steering wheel where it meets the column might be required. I bought mine from someone who had already done everything to make it work, so I'm not 100% sure. I do know the splines are the correct size and will fit fine that way.
Old Nov 10, 2006 | 10:35 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stinkycheezmonky &raquo;</TD></TR><TR><TD CLASS="quote">The only thing you'd need with a JDM ITR (at least the non-SRS one) is a little spacer between the wheel and the column. I used a pair of washers stuck together, and that worked fine.
Edit: Actually, some modification to the back of the steering wheel where it meets the column might be required. I bought mine from someone who had already done everything to make it work, so I'm not 100% sure. I do know the splines are the correct size and will fit fine that way.</TD></TR></TABLE>
Huh? I didn't have to do anything. Just remove old wheel and stick on JDM ITR wheel.
Old Nov 10, 2006 | 11:42 AM
Suspetise...
Mine had a gap between where the back of the wheel met the column and where the nut ended. It's a little hard to describe, but without that spacer, it seemed like the wheel would've wobbled around a bunch, even bolted down.
Eg6_k20
Sep 15, 2010 11:02 PM
Happyman
13
Feb 14, 2003 02:50 PM
JUNcr-x
Jul 12, 2002 09:46 AM
