timing with tilton clutch
Old Nov 9, 2006 | 02:48 AM
hyabusa hunter's Avatar
Default timing with tilton clutch
hello everyone, i have a problem on my hands,
i have installed a tirlon twin disc clutch.... BUT.... i cant seem to time the motor, all you H22 fans know that you have to pull the bung on the gearbox housing to see the flywheel, well the tilton flywheel sits way far back and you cant really see it, o know there are timing marks on it cause i saw them when i looked at the flywheel! so HELP!!!!!!
this is posted in "forced induction" any help will do!
Old Nov 9, 2006 | 04:48 AM
kulrevon's Avatar
Default Re: timing with tilton clutch (hyabusa hunter)
the timing marks should have been right next to the teeth for the starter. is there anyway you put the flywheel on or put the camshaft 180 off. if so you would want to use the #4 cylinder I believe to time.
put the motor so #1 piston is at tdc. (ether a screwdriver in the spark plug hole or the cam gear lines.) and rotate the motor by hand slowly to see if you can locate the marks.
if not try it 180 degrees out.
Old Nov 10, 2006 | 08:40 AM
Default Re: timing with tilton clutch (kulrevon)
hey....? i dont get ya?
Old Nov 10, 2006 | 09:36 AM
PrecisionH23a's Avatar
The answer you received in the FI forum is correct. Go with that answer.
meanshyguy
Aug 24, 2009 03:43 PM
prelude2.2vtec
Mar 3, 2009 04:31 AM
hyabusa hunter
Jan 3, 2007 04:28 AM
mayhemdestroy
Aug 23, 2005 06:20 PM
BoostedH23a1
Dec 15, 2003 01:48 PM
