rmf and smsp header question
Old Nov 8, 2006 | 07:57 PM
championshipwhite93si's Avatar
Default rmf and smsp header question
ive been going back and forth on these two headers for a little bit now, i just have one question. im worried about it cracking over the long run, due to it not having a flex pipe. just curious if anyone has put one in after the header or had any problems with cracking at all.. i just dont wanna pay a g for a really good header and then down the road the wear an tear on it from the motor vibrating and such causes it to crack...
Old Nov 8, 2006 | 08:08 PM
darkspector2.0's Avatar
the welds are so strong... I've seen pictures of one of the two totally smashed in the pipes all messed up but no cracks
Old Nov 8, 2006 | 08:20 PM
CGags13's Avatar
Default Re: rmf and smsp header question (championshipwhite93si)
both rmf and smsp strongly recommend that you run a flex pipe (its best to put it on the end of the header)
Old Nov 8, 2006 | 08:30 PM
98vtec's Avatar
moderator emeritus
Default Re: rmf and smsp header question (CGags13)
flex pipe is recommended. If it cracks and you are not running a flex pipe, it WILL NOT be covered, but you can pay him to fix it.
Old Nov 8, 2006 | 08:35 PM
K-Spec's Avatar
Default Re: rmf and smsp header question (98vtec)
what about bolts with springs and a flex donut?
Old Nov 8, 2006 | 09:02 PM
98vtec's Avatar
moderator emeritus
Default Re: rmf and smsp header question (K-Spec)
that would be ok, just so long as the exhaust has the ability to give.
and whats up with everyone changing their got damn names!
Old Nov 8, 2006 | 09:06 PM
K-Spec's Avatar
hahaahha
you should change yours to 98vTak_y0!
Old Nov 8, 2006 | 09:19 PM
A Blue Lude's Avatar
I believe Dave's headers are generally setup to use donut joints, which accomplishes the same thing as a flex pipe.
Old Nov 8, 2006 | 09:24 PM
CGags13's Avatar
yea really im staying old school and keeping my name...i tend to lean towards the flex pipes myself...they seem to allow more play which is always nice with my exhaust draggin ***
Old Nov 9, 2006 | 08:02 PM
94vtirozguy's Avatar
SMSP as stated above are made to use donut joints.
Old Nov 9, 2006 | 09:01 PM
SMSP's Avatar
Default Re: (94vtirozguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94vtirozguy &raquo;</TD></TR><TR><TD CLASS="quote">SMSP as stated above are made to use donut joints.</TD></TR></TABLE>
That's right for any with a 2-1/2" collector outlet. If it has a 3" outlet then we go with a flex pipe since I haven't found a donut and flange set up. BTW, I've never had a H series header crack.
Old Nov 10, 2006 | 05:17 AM
K-Spec's Avatar
Default Re: (SMSP)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SMSP &raquo;</TD></TR><TR><TD CLASS="quote">
BTW, I've never had a H series header crack.</TD></TR></TABLE>
yep SMSP
Old Nov 10, 2006 | 05:31 AM
Revi's Avatar
Default Re: (K-Spec)
Are both of these headers still a million bucks or have they gone down in price? I want to try one on my Type-S to see what it does but damn, they are expensive!
Old Nov 10, 2006 | 05:42 AM
2lude4u's Avatar
Default Re: (Revi)
They are worth every cent though.
Hytech is also set up with a donut joint.
K-Spec's Avatar
Default Re: (Revi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Revi &raquo;</TD></TR><TR><TD CLASS="quote">Are both of these headers still a million bucks or have they gone down in price? I want to try one on my Type-S to see what it does but damn, they are expensive!</TD></TR></TABLE>
ya they went down in price, they're only $1200 =P
Old Nov 10, 2006 | 05:49 AM
M2B4's Avatar
i was quoted 1100 from 98vtec on my rmf. which i should be buying come the begin of next year
Old Nov 10, 2006 | 07:22 AM
prelude_h22vtec's Avatar
i only gotta save like 200 more dollars....next thing on my list
Old Nov 13, 2006 | 08:24 PM
the SMSP quality is the best i have seen on a header.
Old Nov 13, 2006 | 08:26 PM
98vtec's Avatar
moderator emeritus
is that the only custom header you have seen?
RMF, SMSP, Hytech, SSR all have top notch quality.
Old Nov 13, 2006 | 08:28 PM
mgags7's Avatar
Default Re: (B.Rabbit)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B.Rabbit &raquo;</TD></TR><TR><TD CLASS="quote">is that the only custom header you have seen?
RMF, SMSP, Hytech, SSR all have top notch quality.</TD></TR></TABLE>
B.Rabbit? lol
hahhaha
my rmf+flexpipe is still in tact fine....
Old Nov 13, 2006 | 09:13 PM
Televator's Avatar
I got your flex pipes right here!!!
I remember reading in a mag that Hytech uses some kind of nascar designs in their headder. Something that aids scavenging. Suposedly patented and everything. Has anyone else heard that?
Oh, and I'm sticking with my user name for a good while. I like it, and I think it's memorable.
Old Nov 13, 2006 | 09:15 PM
98vtec's Avatar
moderator emeritus
Default Re: rmf and smsp header question (Televator)
they are called anti-reversion chambers. And some people show disbelief in anti-reversion chambers because exhaust pulse reversion can be used to "pull" the exhaust once the exhaust valve opens. This is all assuming that you can time the reversion pulse correctly.
Old Nov 13, 2006 | 09:27 PM
Televator's Avatar
Default Re: rmf and smsp header question (B.Rabbit)
So...does that mean it keeps it from sending the negative pulse? I thought the name of the game was to take advantage of it? Maybe I misunderstood.
Old Nov 14, 2006 | 03:01 PM
SMSP's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Televator &raquo;</TD></TR><TR><TD CLASS="quote">I got your flex pipes right here!!!
Oh, and I'm sticking with my user name for a good while. I like it, and I think it's memorable. </TD></TR></TABLE>
Jim Fueling has the design patent on the AR chamber. NASCAR doesn't use them. They work for low rpm engines.
Old Nov 14, 2006 | 06:54 PM
Default Re: rmf and smsp header question (SMSP)
nascar ownage
