Are these rods still useable...rusty
Old Nov 8, 2006 | 07:24 PM
drumminforev's Avatar
Default Are these rods still useable...rusty
They have rust as you can see....can they be used as is with no concerns.
Old Nov 8, 2006 | 08:09 PM
milano2kdc2's Avatar
rust is like cancer. would you put a cancerous tumor into your body to save some dollars?
Old Nov 8, 2006 | 08:15 PM
Steven.'s Avatar
They're still look useable, but what happens when one breaks from rust?
is it possible to sand some rust off?
Old Nov 8, 2006 | 08:32 PM
crimsonv4mpire's Avatar
Default Re: Are these rods still useable...rusty (drumminforev)
sand blaster.
Old Nov 8, 2006 | 08:58 PM
Luserkid's Avatar
Default Re: Are these rods still useable...rusty (crimsonv4mpire)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crimsonv4mpire &raquo;</TD></TR><TR><TD CLASS="quote">sand blaster.</TD></TR></TABLE>
Should be able to take it right off, although that one that you took a close up look on looks pretty bad you might need to sand blast then shot peen it as well.
Now that i looked closer those are just stock rods anyway. What i would do is take those pistons and put them on your rods.
Old Nov 8, 2006 | 09:08 PM
jadugartir's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crimsonv4mpire &raquo;</TD></TR><TR><TD CLASS="quote">sand blaster.</TD></TR></TABLE> x2
Old Nov 8, 2006 | 10:04 PM
Tatakai's Avatar
Default Re: Are these rods still useable...rusty (Luserkid)
2 options;
if you just need a set of working rods for the daily beater (BEATER, as in 200k and still goin)
if you plan on doing any performance mods later
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">
Now that i looked closer those are just stock rods anyway. What i would do is take those pistons and put them on your rods. </TD></TR></TABLE>
I vote option #2
Old Nov 9, 2006 | 12:15 AM
quik sol's Avatar
it LOOKS like surface rust or oxidation, have them cleaned and they will be good to go
Old Nov 9, 2006 | 12:25 AM
TranspeedMotorsports's Avatar
Get another set of used rods.
Old Nov 9, 2006 | 07:41 AM
Default Re: (Transpeed Motorsports)
How do I know which rods these are. they are civic type r pistons...so they are type r rods as well?
Old Nov 9, 2006 | 08:02 AM
Luserkid's Avatar
Default Re: (drumminforev)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drumminforev &raquo;</TD></TR><TR><TD CLASS="quote">How do I know which rods these are. they are civic type r pistons...so they are type r rods as well? </TD></TR></TABLE>
See this picture:
On the left rod you could see some markings that come out PR3 which is a B16 rod. P73 is i believe Type R rods, PR4 is LS/B20, P72 - GSR. Look at all the rods and see whats stamped on.
Old Nov 9, 2006 | 08:09 AM
slwburn's Avatar
Default Re: (Luserkid)
Try putting them in some coke for a bit... its only surface rust they should clean up nice. You may want to use some steel wool too.
Once you've cleaned the coke off put some oil or another corrosion inhibitor on them if your not going to use them right away.
Old Nov 9, 2006 | 03:49 PM
Default Re: (slwburn)
So these are all pr3, which is b16. So i could put these in a b16 just like this and be higher compression.
Old Nov 9, 2006 | 04:18 PM
R1Motorsports.com's Avatar
Clean them up and use them, it looks like that's just surface rust.
Old Nov 9, 2006 | 04:36 PM
lil vin's Avatar
just buy new ones
Old Nov 9, 2006 | 04:39 PM
JDM-97CX's Avatar
Default Re: Are these rods still useable...rusty (lil vin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lil vin &raquo;</TD></TR><TR><TD CLASS="quote">just buy new ones </TD></TR></TABLE>
Why?
Use a die grinder and a Roloc to clean the rust off. It will take all of two minutes.
Old Nov 9, 2006 | 04:59 PM
imknotright's Avatar
I agree, clean them don't ditch them. Soak them with some rust penetrant such as PB Blaster or WD40. Let them soak for a bit then hit them with some steel wool. Next clean them & oil them up like a couple of stripppers on a slip & slide....you get the point
SilverWarrior
Aug 24, 2008 08:38 PM
JDM EM1 17
May 19, 2008 08:19 AM
phantomeg6
48
Apr 29, 2007 05:07 PM
ericstambaugh07
22
Feb 21, 2007 04:44 PM
B20 BEAST
Apr 24, 2003 06:58 PM
