Changing the A to H emblem in rear
I have done several searches but nothing came up. I have a few questions for those of you that have changed the A emblem to the H emblem in the rear. Which H emblem do I want to purchase and where could i get it for a good price? Is the process hard? Anyone have directions on how to do it? Any info appreciated. Thanks.
Just get an OEM H from an integra (about $50). Take the A off with Dental floss and adhesive remover and put the H on. easy as cake....and also good for 10 whp
How exactly would I use dental floss to take the A off? And what is adhesive remover? Last of all, you guys know where I could get the OEM H? Thanks.
http://www.ipsracing.com
Call up Mike. he has them
Take the floss and shimmy it behind the emblem. teh floss wont scratch the paint and then after you separate the double sided tape from the car and emblem... use thet remover to clean up your trun and then re apply the new badge!!!!
that looks nice. i wanted to do mine for a bit now . .
whats the front look like on usdm front end.
the rear looks good. but the front seems too round for the h emblem .
WOW 10 HP FROM JUST THAT ? is that to the wheels?
[QUOTE
Take the floss and shimmy it behind the emblem. teh floss wont scratch the paint and then after you separate the double sided tape from the car and emblem... use thet remover to clean up your trun and then re apply the new badge!!!![/QUOTE]
Can I use the same method to remove the one in front bumper?
The front is a bit tricky. On mine the emblem did NOT want to come off the pegs where stuck in funny and its plastic so I didn’t want to jack it. As far as the emblem, you have to use the same emblem as the back because the JDM front emblem is rounded too much for the surface of the USDM bumper where the emblem sits. You also will need to chop the pegs off because the pegs on the emblem are closer together on the front emblems.
[Modified by IntegraT, 10:29 PM 5/7/2002]
i didnt think there were pegs on the front one , i thought only the backs .
a least from what i remeber thats how my 99 teg was
the front was more of a pain though , ******* urathne
Get yourself some Australian Emblems and they will fit perfectly. For all intents and purposes our R is externally identical to the US Type R (few differences with wheels etc )
I thought of this as well when I did mine (AUS, UK) but they were just to hard to get a hold of.
P.S.
They also have the "HONDA" badge that will fit in the "ACURA" holes perfectly.
P.S.
chippy
Apr 17, 2008 09:16 AM
jet
Oct 10, 2001 03:56 AM
