Turbo LS - why is my car soo damn hot? ac blows hot air, even with ac off, blows hot air
is there anything i can do to make my car a little less hot? or at least blow out cold air?
anyone else have these issue or is it just me.
i have the same problem... I dont have A/C but its Fall and where I live its pretty cold... but when i drive my car around it still blowz out warm air..
see if the cable that runs to you coolant valve from your inside climate control
your cable is probably not installed correctly
i dont think its the cable. although it is one of the problems since i installed the type r carbon fiber climate control.
wtf does the dump tube do? i have a drag kit and was wondering if the dump tube is way too short? should i buy a pipe and just direct the exhaust fumes under the car instead of the engine bay?
i probably need a bigger radiator too.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by btech »</TD></TR><TR><TD CLASS="quote">wtf does the dump tube do? i have a drag kit and was wondering if the dump tube is way too short? should i buy a pipe and just direct the exhaust fumes under the car instead of the engine bay?
i probably need a bigger radiator too. </TD></TR></TABLE>
Most off topic post Ive ever seen
hey its better then making a new topic right?
so anyone know why the car blows out hot air? my radiator too small? should i use some heat wrap on my ac lines?
