99-00 SI Compustar major problem read inside.
Well my friend was putting my compustar remote start alarm in 00 SI today. Big problem the remote start does not work. It works if the key is in the ignition. If they key is out of the ignition it does not work. Any particular reason why? Help PLEASE!!!
i also have a compustar alarm and remote start. my uncle has instauled a lot of these. i call him and see what he can come up with or see if he has ever heard of this happening.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jago »</TD></TR><TR><TD CLASS="quote">imobilizer</TD></TR></TABLE>
BINGO. You need to bypass the factory transponder.
You will need this part by DEI, as well as an extra key: 555UW
EDIT: And if the dude you had put it in doesn't know that this is the problem, I wouldn't trust that installation.
FYI...when its installed right, this alarm kicks ***!!
It has so many features. I love the 2 stage shock sensor. I turn it on every night when I go to sleep so even the wind will sometimes set off the alarm. Then turn the 2nd stage off in the morning so all the rice burners and garbage trucks don't set it off.
ehhh... there's no immobilizer in a 99-00
Other than wiring... Start the car-> use the remote start-> remove keys, get out and arm the alarm-> use remote start to shut car off-> see if you can remote start while armed.
Some remote starts have a safety feature like this for use with manuals to ensure it's not in gear...
Well i just found out that my car has a honda factory alarm system installed. Do you think this has anything to do with it? The factory alarm system is triggered by the door locks and trunk. LMK thanks!
The remote start has to be set by using the turbo timer by the alarm, other words, while the car is on, take your key out and your car should say running. Make sure your car is in neutral which is the only way it will work. Do not press the brake to turn the car off. As it's running, get out and close your door. Your alarm will set as well as your remote start. It's just a safety feature compustar made so your cannot leave the car in gear. If you try to use the remote start any other way, it will not work.
Yes i know this. The problem is the car wants to start but it doesnt. You can hear the started click and try to turnover, but it seems as if something is stopping it from cranking all the way over.
your wiring is wrong.. One of your IGNs is not hooked up or you have the accessorie wire going to it.. the green compustar wire should be going to black yellow.. and the blue one should be going to yellow. but remember to hook up the relay on the blue wire..
How did you bypass the clutch ?
12 VOLTS white + ignition harness
STARTER 1 black/white + ignition harness or In 6 pin white plug behind fuse box
STARTER 2
IGNITION 1 black/yellow + ignition harness
IGNITION 2 yellow + ignition harness
IGNITION 3
ACCESSORY 1 white/black + ignition harness
ACCESSORY 2
KEYSENSE
POWER LOCK green/white - keyless entry module The keyless entry module is white in color, and located in the drivers kick panel.
POWER UNLOCK green/orange - keyless entry module The keyless entry module is white in color, and located in the drivers kick panel.
DOORLOCK MOTOR white/red drivers kick panel
DOOR UNLOCK MOTOR blue/red drivers kick panel
DISARM NO UNLOCK
FACTORY ALARM ARM
FACTORY ALARM DISARM
DISARM DEFEAT yellow/red keyless entry module The keyless entry module is white in color, and located in the drivers kick panel.
PARKLIGHTS POSITIVE red/black + keyless entry module The keyless entry module is white in color, and located in the drivers kick panel.
PARKLIGHTS NEGATIVE -
HEADLIGHT
HAZARD
TURN LEFT
TURN RIGHT
REVERSE
BRAKE green/white + brake pedal switch
PARKBRAKE
DOOR PIN lt. green/red - oem alarm plug The OEM alarm plug is to the right side of the steering column. The plug is green.
HOOD PIN
TRUNK PIN blue/black - oem alarm plug The OEM alarm plug is to the right side of the steering column. The plug is green.
DOMELIGHT SUPERVISION same as doors
TACH blue test connector Drivers side fire wall under hood in a 2 pin plug
VSS
GLOW PLUGS
TRUNK RELEASE
SLIDEDOORS
LEFT FRONT UP/DWN red/yel - red/blu A drivers door switch
RIGHT FRONT UP/DWN blu/yel - blu/org A drivers kick panel
LEFT REAR UP/DWN grn/yel - green A drivers kick panel
RIGHT REAR UP/DWN yellow - yel/grn A drivers kick panel
SUNROOF LIMIT
SUNROOF OPEN/CLOSE
MEMORY SEAT 1
MEMORY SEAT 2
MEMORY SEAT 3
HORN gray - oem alarm plug The OEM alarm plug is to the right side of the steering column. The plug is green.
DEFROST
WIPER
RADIO 12V
RADIO GROUND black - radio harness
RADIO SWITCH yellow/red + radio harness
RADIO ILLUMINATION red/black + radio harness
FACTORY AMP TURN ON n/a
POWER ANTENNA n/a
LEFT FRONT SPEAKER blue/green - gray/black +,- radio harness
RIGHT FRONT SPEAKER red/green - brown/black +,- radio harness
LEFT REAR SPEAKER blue/yellow - gray/white +,- radio harness
RIGHT REAR SPEAKER red/yellow - brown/white +,- radio harness
STARTER 2
IGNITION 3
ACCESSORY 2
KEYSENSE
DISARM NO UNLOCK
FACTORY ALARM ARM
HEADLIGHT
HAZARD
TURN LEFT
TURN RIGHT
REVERSE
PARKBRAKE
HOOD PIN
VSS
GLOW PLUGS
TRUNK RELEASE
SLIDEDOORS
SUNROOF LIMIT
SUNROOF OPEN/CLOSE
MEMORY SEAT 1
MEMORY SEAT 2
MEMORY SEAT 3
DEFROST
WIPER
RADIO 12V
POWER ANTENNA n/a
iam7head
Audio / Security / Video
10
Oct 9, 2008 05:33 AM
