em stud pulled out with nut(no pun intended)
Old Nov 8, 2006 | 02:07 PM
HondaHeddie's Avatar
Default em stud pulled out with nut(no pun intended)
I asked this as a 2nd q in this thread
https://honda-tech.com/zerothread/1805019
but did not put it in the heading
so here it is
I am replacing my em gasket
when I removed the nuts one of the nuts came with the stud threading out of the head instead of the nut threading off the stud
should I just thread the stud back in and torque it like I am torqueing the nuts on the studs that are set
or........
Modified by HondaHeddie at 5:18 PM 11/8/2006
Old Nov 8, 2006 | 02:19 PM
Default Re: em stud pulled out with nut(no pun intended) (HondaHeddie)
bump
its getting dark and I want to finish
Old Nov 8, 2006 | 02:54 PM
colnago's Avatar
just torque the nut with the stud attached as you would if they were seperate. The old gasket was probably made of graphit. Scrape all material off completely then use acetone to prep surafce. Acetone very good at removing oil,etc. you can also remove nut from stud by holding stud with vise grips by the none threaded part of shaft, and then remove nut.
good luck
thatcivic96
May 17, 2014 09:50 PM
WhiteOnRice
Oct 8, 2007 11:58 AM
pinecone
May 29, 2007 12:30 PM
95GSRTT
Apr 30, 2005 05:57 PM
Flamenco-T
Nov 1, 2002 08:23 PM
