91 da auto to manual conversion, mount question
Old Nov 8, 2006 | 01:59 PM
unclecaveman's Avatar
Default 91 da auto to manual conversion, mount question
the car is an auto and i am about to buy a trans to convert it and i was wondering what motor mount to use, should i use the stock (manual) motormount from a junkyard da?i heard you have to move the pocket mount on the car (cut and weld) but i dont know if i believe that, the trans is a 1990 jdm b16 j1 trans from a front clip of a civic and it is cable, im just wondering if i have to get an after market motor mount...
any thing you know that would help me acomplish this easier would be appreciated
Old Nov 8, 2006 | 08:26 PM
BuddhaSiR's Avatar
Default Re: 91 da auto to manual conversion, mount question (unclecaveman)
its been a while since i did that swap on my cousins DB. I think i used the manual tranny mount. What i remember is i used washers in between the mount and the tranny to make it sit in properly. Without the washers it looked very lopsided.
Old Nov 9, 2006 | 11:53 AM
projectTeG's Avatar
you have to shim the manual mount up 1 inch, what i did was went to napa and got 3 one in think larger inner diameter grade 8 nuts and i got 3 1 inch longer bolts for the tranny mount and put them in and went drivinv. i had that running and no problems with it. BTW you do need the manual mount.
Old Nov 10, 2006 | 10:17 AM
mec. pedri's Avatar
i did one of those back in '01 and I used a conversion mount from PLACE RACING.
the motor sat nice and even
grand champ
25
Jun 12, 2014 06:08 PM
DA3
Apr 18, 2008 02:55 PM
stackz
Nov 15, 2006 01:04 PM
eg8ferio
Apr 26, 2006 12:44 PM
gsp ej1-em1
Feb 26, 2006 06:52 AM
