Suspension & Brakes Theory, alignment, spring rates....
beaks vs. asr rear sway kit?
Old Nov 8, 2006 | 11:04 AM
killerpenguin21's Avatar
Default beaks vs. asr rear sway kit?
this is going on a 96 ek coupe (ej8)
any input?
Old Nov 8, 2006 | 11:20 AM
D-booster's Avatar
Default Re: beaks vs. asr rear sway kit? (killerpenguin21)
I have the Beaks, they work perfect. only difference is...ASR kits brace the whole subframe. You would have to buy Beaks stress bar as an add on to do the same.
Old Nov 8, 2006 | 11:37 AM
di2ferio's Avatar
Default Re: beaks vs. asr rear sway kit? (D-booster)
i would rather go with the ASR not just cuz i have one but i've only heard good reviews about it... but i've heard some bad stories about the beaks kit, and how it still rips the subframe
Old Nov 8, 2006 | 01:06 PM
SkankyEJ7's Avatar
Default Re: beaks vs. asr rear sway kit? (di2Ferio)
asr hand down
Old Nov 8, 2006 | 04:35 PM
Got Utensils's Avatar
Default Re: beaks vs. asr rear sway kit? (SkankyEJ7)
if you have a choice between the both go with ASR! its alot more reinforcement than the BEAKS kit.
Old Nov 8, 2006 | 05:45 PM
Hairy Hudson's Avatar
This is a good post because I was wanting to ask the same question. I have a 26mm mugen sway bar for my 96 HB, I like the price of the beaks because I can buy it now. The asr I will have to hold off another month or 2. Is a 26mm to much for beaks?
Old Nov 8, 2006 | 06:24 PM
B16B_coupe's Avatar
HRD PKR
Default Re: beaks vs. asr rear sway kit? (nateberry103)
yeah asr!! thats what iam buying for my coupe
Old Nov 8, 2006 | 06:49 PM
SkankyEJ7's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nateberry103 &raquo;</TD></TR><TR><TD CLASS="quote"> This is a good post because I was wanting to ask the same question. I have a 26mm mugen sway bar for my 96 HB, I like the price of the beaks because I can buy it now. The asr I will have to hold off another month or 2. Is a 26mm to much for beaks?
personally i think the itr is to big for the beaks, if you dont have the proper spring setup
Old Nov 8, 2006 | 06:50 PM
kartman's Avatar
Just bought the ASR kit and 23 mm JDM / ITR
rear sway bar. A great looking and working
combination.
Old Nov 9, 2006 | 09:30 AM
well this is being combined with blox lca's and ksport full coils
Old Nov 9, 2006 | 02:58 PM
nonsense's Avatar
I'd get the ASR personally. I'm running a beaks kit right now, but the fear of ripping out the Subframe made me disconnect an endlink. It's just not worth the risk of having a tearout. The EG/DC chassis was a much better subframe design and they can handle the beaks kit, the EKs are different so the subframe is more likely to rip.
Old Nov 9, 2006 | 10:29 PM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: beaks vs. asr rear sway kit? (nonsense)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nonsense &raquo;</TD></TR><TR><TD CLASS="quote">I'd get the ASR personally. I'm running a beaks kit right now, but the fear of ripping out the Subframe made me disconnect an endlink. It's just not worth the risk of having a tearout. The EG/DC chassis was a much better subframe design and they can handle the beaks kit, the EKs are different so the subframe is more likely to rip.
Yup. EG/DC subframe is usually fine with a beaks kit, but the EK I would definatly recommend the ASR.
Old Nov 15, 2006 | 03:23 PM
Thanks for your input on that! I did not know that there was a differance in strength from EG/DC to the EK chassis. I guess it's like that old rule my parents have always told me "you get what you pay for"
Old Nov 15, 2006 | 03:29 PM
BodyKits NW's Avatar
I've always recommended ASR to all our customers. Their customer service is great, as well as the design. For the price and what they have to offer you really can't go wrong with them.
Old Nov 15, 2006 | 06:53 PM
CarbonizedDX's Avatar
I'm with the ASR vote: The other thing to remember is that the ASR brace not only bolts to the lca bolts but also to the bolt openings for the oe swaybar and that's a three point frame tie in (on each side) as well as a larger surface to distribute the load accrost.
spikerockz
Nov 10, 2005 08:06 AM
mrdeadman
Aug 1, 2005 02:47 PM
Maxboost808
Jun 16, 2004 02:01 PM
Kev95lx
Sep 26, 2003 05:54 AM
SpoonSportsFanatic
Apr 2, 2002 06:23 PM
