Help. Alternator Adjustment Bolt
Old Nov 8, 2006 | 05:19 AM
Flux's Avatar
Default Help. Alternator Adjustment Bolt
I've managed to lose the alternator adjustment bolt. Does anybody know the size/type of that bolt?
thanks.
edit: I have the OEM bolt part number (90058-P72-000). But I'd rather jsut run down to the hardware store and pick one up if possible.
Modified by Flux at 8:36 AM 11/8/2006
Old Nov 8, 2006 | 11:18 AM
Flux's Avatar
Default Re: Help. Alternator Adjustment Bolt (Flux)
Wow, nobody?
Old Nov 8, 2006 | 11:23 AM
migs's Avatar
I know it uses a 12mm head. My guess would be 10x1.25mm
RTW DC2R's Avatar
bolt or nut?
there are probably other nuts on the car that are the same size. maybe see if you can find one and see if it screws on? then you can go to the hardware store and try to match it.
first ones that comes to mind are the strut tower.
Old Nov 8, 2006 | 12:08 PM
Flux's Avatar
Default Re: (RTW DC2R)
This is the bolt that you loosen to swivel the alternator to adjust the belt tension - it is the upper bolt . I'm not sure what nut you are referring to.
I'm assuming it is a bolt.
Old Nov 8, 2006 | 02:59 PM
rcar97's Avatar
Default Re: (Flux)
Just go to the dealer and they'll give you the right bolt. Don't chance it.
I had a rounded adj bolt and had to chisel it off and repair the through bolt.
Old Nov 8, 2006 | 05:06 PM
Flux's Avatar
Default Re: (rcar97)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rcar97 &raquo;</TD></TR><TR><TD CLASS="quote">Just go to the dealer and they'll give you the right bolt. Don't chance it.
I had a rounded adj bolt and had to chisel it off and repair the through bolt.</TD></TR></TABLE>
I just ordered one...
Old Nov 8, 2006 | 09:08 PM
Chris F's Avatar
With it hanging near the alternator it might end up being a corrosion resistant bolt... probably a decent idea to go ahead and do what you already did
Anyone know if it is/isn't?
SperoATX
Jul 7, 2015 09:07 AM
Premium Dude
Jul 23, 2013 06:50 PM
Chipped B6
19
Feb 21, 2009 04:39 PM
kaoss_11
Jul 15, 2004 12:22 AM
