Where to buy Folding Tow Hook
Instead of a hook try considering a tow strap instead?
>> http://www.safequipracingprodu...c.htm
search BMW tow hook on ebay. they have them for about 55 bucks.
if anyone else has any other places list them. Im about to buy one too.
http://cgi.ebay.com/ebaymotors...ZWD1V
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by APEX CRX »</TD></TR><TR><TD CLASS="quote">Instead of a hook try considering a tow strap instead?
>> http://www.safequipracingprodu...c.htm</TD></TR></TABLE>
This is what I used.
The tow straps looks like a great idea. How is it mounted.
Would you have a picture mounted?
The BMW / S2000 is what i found as well. Just wasn't sure if they would work.
I used some thick steel cable with nylon shell from home depot. It worked, hasn't had a real tough workout but I did get my car towed like that. Doubled over (like, in a loop/circle) you get double the tensile/break strength.
I'll try to take a pic but until then this is how I installed my to strap. I used on of those boaters 'U' clamps from home depot (the 3k lbs kind) and attached it to my left front tow hook. I then routed the tow strap through the front of the bumper where the factory foglights would go. And just to make sure it stays put, I keep a tie wrap aroundn it and the bumper. It works like a charm even when you being towed off the track
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VenWood »</TD></TR><TR><TD CLASS="quote">Have you had experience being towed off track?</TD></TR></TABLE>
YES? why? The safequip straps come with a flat plate to make it easy to bolt on
Just don't loop an old seatbelt around your bumper beam and out a slot in the bumper cover. A careless tow driver can snap the tow rope tight and pull the beam right through the bumper cover........ask me how I know.
egtype-r
19
Mar 17, 2004 08:14 AM
