couple questions about hondata + nitrous + boost
Old Nov 7, 2006 | 08:05 PM
dafuzzbudd's Avatar
Default couple questions about hondata + nitrous + boost
ive read through the hondata.com site
1.) it isnt clear where you get a boost solenoid/ where is it installed
2.) what are these "compontents" that need to be added to the ecu
3.) the site says boost is controlled by gear, my idea is to have a button somewhere for +boost; is this able to be done?
4.) after the nitrous is wired does hondata control your injectors or are you forced to use seperate nitrous fuel control
5.) with nitrous wired up you are still able to use your normal button, correct?
6.) does aem wideband have compatability problems?
ill ask on the hondata forum for anything else
i would post there first but i like it better here
thanks to anyone with helpful info
Old Nov 9, 2006 | 09:05 AM
dafuzzbudd's Avatar
Default Re: couple questions about hondata + nitrous + boost (dafuzzbudd)
bump
Old Nov 11, 2006 | 08:51 PM
dafuzzbudd's Avatar
bump
Old Nov 12, 2006 | 03:13 PM
mr_carman007's Avatar
bump for good questions that i wanna know the answers too also
Old Nov 14, 2006 | 03:16 PM
dafuzzbudd's Avatar
Default Re: couple questions about hondata + nitrous + boost (mr_carman007)
bump
Old Nov 15, 2006 | 09:36 PM
dafuzzbudd's Avatar
oh.. just some kind of input please
Old Nov 24, 2006 | 04:15 AM
dafuzzbudd's Avatar
for a reference
all the answers = http://www.hondata.net/forum/viewtopic.php?t=5631
Modified by dafuzzbudd at 9:12 PM 11/24/2006
Old Dec 2, 2006 | 07:34 PM
Cali4niaEk9's Avatar
I WANT 2 GO BIG ON NITROUS!!!!!!!!!! i want to know what do i change or do to Use as much NITROUS as i can On Race Gas on the Track on my All motor Setup!!!!!!!!
B20b block Stock Sleeves Block Guard 84.5mm Arias 11:8:1 Piston
Rods are Pinned (stock)
Type R water/Oil Pump
Ctr Pully
Custom Head Gasket for High Compression
B16 Head Ported/Polish Full Omni Valvetrain
Milled HEAD 440Injectors
Jun 3's or Have Custom DH RACING CAMS
Rage Header 2.0 Big Tube
Want to Know what Spark Plugs to run? Wat to Change !!!!
Wats biggest i can go On Squeez?
What System To BUY???????????
Old Dec 2, 2006 | 08:52 PM
dafuzzbudd's Avatar
Default Re: (Cali4niaEk9)
are you serious?
problems:
1.) you talk like a fool
2.) you brought this crap into my thread
3.) your "question" has nothing to do with the title
eg6madness
Jun 22, 2010 10:02 PM
citrusdrop
Mar 8, 2009 12:07 PM
ludeDVR
Oct 7, 2005 11:55 AM
mrbsponge
Mar 10, 2005 07:11 AM
boosted hybrid
Jun 9, 2003 03:30 AM
