from d16y8 to d16z6 in crx questions
Old Nov 7, 2006 | 07:52 PM
Maireeka's Avatar
Default from d16y8 to d16z6 in crx questions
Hi, I just bought a 1990 CRX Si with a running OBD1 d16y8 swap. The problem is that the motor smokes (blue) like a mother and burns a half a quart every 100 miles (if you baby it.) The plugs are oily. I am pretty sure its the rings, so the engine needs to be rebuilt.
I found a d16z6 for sale for 400 dollars from a shop near my house. I want to put the z6 in my CRX, and was wondering what I needed to take off the y8 and put on the z6 for it to run right.
I was thinking about the
distributor
clutch
intake mani
exhaust mani
different sensors?
Could i just take the block, oil pan, head, and valve cover of the z6, and bolt everything (dizzy intake/exhaust mani clutch flywheel tranny) from the y8 on? Will the clutch and flywheel work with the si tranny i'll be using?
Old Nov 7, 2006 | 10:07 PM
13g-crx's Avatar
Yes.Just change out the block and head. If it was running good before then replace only whats bad. The clutch/flywheel will bolt onto the z6 just as did with the y8.
Old Nov 8, 2006 | 05:38 AM
Maireeka's Avatar
Default Re: (13g-crx)
Thanks a ton, man. Now all I gotta do is scrape up the money for the motor!
Old Nov 8, 2006 | 02:44 PM
jlicrx's Avatar
Default Re: from d16y8 to d16z6 in crx questions (Maireeka)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Maireeka &raquo;</TD></TR><TR><TD CLASS="quote">Hi, I just bought a 1990 CRX Si with a running OBD1 d16y8 swap. The problem is that the motor smokes (blue) like a mother and burns a half a quart every 100 miles (if you baby it.) The plugs are oily. I am pretty sure its the rings, so the engine needs to be rebuilt.
distributor
clutch
intake mani
exhaust mani
different sensors?
</TD></TR></TABLE>the distributor will not bolt to the Z6 head - clutch and flywheel will work fine
Old Nov 8, 2006 | 08:22 PM
Maireeka's Avatar
Default Re: from d16y8 to d16z6 in crx questions (jlicrx)
is the wiring for the z6 the same as the y8? how about the intake manifold?
Old Nov 8, 2006 | 08:40 PM
13g-crx's Avatar
Its already obd1 so I assumed that its prolly already using a z6 distributor. The y8 is the better manifold.
Old Nov 9, 2006 | 05:22 AM
Maireeka's Avatar
thanks, I'm just trying to make sure the wiring will all be straight when I go to hook her up.
Patrick
RNPoo7
Sep 1, 2006 08:17 AM
boostincoupe
Apr 21, 2006 07:45 AM
ATS*VEEE
20
Nov 3, 2002 09:57 PM
