questions about b18c1 engine
I love threads like this. Well lets see.....it could be anything you touched. Thus, you probably put the pistons in upside down and didnt remember to hook the battery back up. Sounds like your problem to me
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95 integra »</TD></TR><TR><TD CLASS="quote">I love threads like this. Well lets see.....it could be anything you touched. Thus, you probably put the pistons in upside down and didnt remember to hook the battery back up. Sounds like your problem to me
.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by microsoft_sux »</TD></TR><TR><TD CLASS="quote">If your getting spark then its probably not the battery. Sounds like your not getting fuel.</TD></TR></TABLE>
Damnit, I was wrong on both accounts then.....who would've thunk it.
.</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by microsoft_sux »</TD></TR><TR><TD CLASS="quote">If your getting spark then its probably not the battery. Sounds like your not getting fuel.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by peter64811 »</TD></TR><TR><TD CLASS="quote">nope everything is hooked up right. the motor is trying to crank. i got power,fuel, and everything else is fine...motor is fairly built</TD></TR></TABLE>
Obviously, you missed the entire point of everyones post. Nobody actually thought you forgot to put the pistons in or didnt hook up the battery. The point is, you posted the most generic crap in the world and expect us to know whats wrong.
Also "everything is hooked up right," well, no, obviously its not because your **** doesnt start.
It really doesnt sound like you have a clue what is going on.
Do you have spark? fuel? timing? what ecu are you using to start this engine?
Do you have everything hooked up? go you have an alarm system on the car? do you have any kill switches?
How is the motor built? what parts? what did the build consist of?
If everything was ok before you did this "build" I am gonna have to say build/installation error
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fida »</TD></TR><TR><TD CLASS="quote">YOUR AN IDIOT
says the noob who cant spell you're
</TD></TR></TABLE>says the noob who cant spell you're
Also "everything is hooked up right," well, no, obviously its not because your **** doesnt start.</TD></TR></TABLE>
hahhahahha
hahhahahha
Well. I would assume you took everything apart only means, Long Block rebuild and you left the Intake manifold, Dizzy, and wire harness, alone. So spark, vacum, and fuel sensors are mostly un messed with. Explain what the engine is doing when you try and start it. How does it sound? What is your level of experiance with engine rebuilding and mechanic work? And WHY did u rebuild in the first place? How many miles are on the engine componets that you didnt rebuild?
