d16 turbo
Old Nov 7, 2006 | 05:35 PM
walsh22's Avatar
Default d16 turbo
I have a 99 Honda Civic DX D16y7 and I wanna turbo it. So I am asking what upgrades I have to get for the motor before its ready for a turbo kit.
Or if I dont turbo would a new intake manifold, headers..etc make a big difference?
Old Nov 7, 2006 | 05:38 PM
Eran's Avatar
HT White Ops
the manifold is a must for a turbo kit, the y7 manifold doesn't work for most turbo aplications (if any), and is a poor design anyways.
and no, a header won't do much if anything for a y7.
Other than the manifold, there is nothing you need to do to the motor to boost it. There are things you can do, such as upgrade the clutch, brakes, suspension, fuel pump, ecu, etc.
If you buy a bolt-on turbo kit, there's not much you absolutely must do other than swap the intake manifold.
Old Nov 7, 2006 | 05:40 PM
wrinkles's Avatar
you can make the y7 manifold work tho
Old Nov 7, 2006 | 05:41 PM
Eran's Avatar
HT White Ops
Default Re: (K Stef)
not very practical though, and you have to get custom piping.
Old Nov 7, 2006 | 05:54 PM
Turbo_y8's Avatar
Default Re: (Eran)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran &raquo;</TD></TR><TR><TD CLASS="quote">not very practical though, and you have to get custom piping.</TD></TR></TABLE>
custom piping?
how about a 90 degree silicon elbow or pipe?
run the piping from the intercooler through the airbox opening(behind headlight where CAI would go) straight pipe to throttle body and elbow. Easy.
but it you would upgrade intake maifolds, go aftermarket from the get go. skunk2, edlebrock....
Old Nov 7, 2006 | 05:59 PM
Eran's Avatar
HT White Ops
Default Re: (Turbo_y8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo_y8 &raquo;</TD></TR><TR><TD CLASS="quote">custom piping?
but it you would upgrade intake maifolds, go aftermarket from the get go. skunk2, edlebrock....</TD></TR></TABLE>
That's still custom, because your modifying to to meed an individual specification, not a blanket application ... regardless of the cost or ease.
custom
adj : made according to the specifications of an individual
And easy or not, a Y7 manifold is still less effective than a Y8 manifold.
Old Nov 7, 2006 | 06:24 PM
UberMunkey's Avatar
turbo d's also like to lift heads. it might be a good idea to invest in some arp head studs if you plan on boosting as well.
Old Nov 8, 2006 | 02:34 PM
Turbo_y8's Avatar
Default Re: (Eran)
custom
And easy or not, a Y7 manifold is still less effective than a Y8 manifold.</TD></TR></TABLE>
i wouldnt call adding a coupler custom, but if it sounds good to you rock it.
Old Nov 8, 2006 | 03:11 PM
DOHCgarage919's Avatar
From: Why To Steal My Car, NC, United States Of America
if i were you i would get the d16y8 intake manifold its bigger in size and better will work perfect with any turbo app
Old Nov 8, 2006 | 03:13 PM
My friend had a d16y7 and it ran like crap because of the y7 mani so when he got the y8 ran perfect
Old Nov 8, 2006 | 03:17 PM
d16T3project's Avatar
Default Re: (DOHCgarage919)
kinda changing the subject... but for a bolt on b16 turbo kit would i need to upgrade the intake mani?
Old Nov 8, 2006 | 04:22 PM
HiProfile's Avatar
Default Re: (d16T3project)
The minimum you need is a good set of injectors. The best price to performance would be had with obd1 conversion (using crome, hondata, etc), a y8 intake manifold and injectors. Based on a 'normal' turbo for that motor, 8-10psi will be safe, as the rods tend to bend once you get into the low-mid 200's for wheel HP. A y8 head isn't needed, since you can 'max' out the stock internals just by upping the boost. With the y7 manifold, I'd do 10psi and leave that last 11psi tuning column just incase it overboosts (10:1 richness and heavy timing retard).
All you'd need with a bolt-on kit made for a y8/z6 motor on a d16y7 would be that 90* elbow. But for ~$100, the y8 manifold is a HUGE step over the y7 manifold.
The best thing you can do to the motor mechanically - make sure it runs PERFECT before boost. SO many slap a kit on, then try fixing problems they had previous that now are severly amplified by boost.
ZakkWylde
Honda Civic (2001 - 2005)
Jun 8, 2007 01:10 PM
k24killer
May 5, 2007 05:52 AM
Jon7
Aug 6, 2001 11:55 AM
