Del Sol Shift Linkage/ Where to buy.
My del sol is in need of a swap. The rings are fried and i think it just ate up an alternator. I would be swapping an obd1 b18b1 into an obd1 del sol. I have all the mounts ect i need, i just need the shift linkage.
i would like to know the cheapest place to get it. I priced it out from honda ( for a del sol vtec) AND IT WAS ALMOST $300. I looked on the hasport website but they had nothing. Where can i get it the cheapest?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bluelxfodo »</TD></TR><TR><TD CLASS="quote">Hasport = 125..i think
Avid Racing has em for 130 shipped it think on ebay
you can try ebay
they should be the same as EKs and EG and DC integras also </TD></TR></TABLE>
not exactly. the del sol linkage has this weird little bend in it. The dc linkage wont work. And i cant use my stock ones cause the little end parts that hook up to the tranny isnt the same for a b-series motor.
you can try ebay
try ebay..they have adjustable linkages....for a little over a hundred...i personally didnt like it... wound up spending 250 at honda no other linkages worked....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deadline »</TD></TR><TR><TD CLASS="quote">dam...why dont u just try ur local junk yard and look for integra shift linkage any model ?</TD></TR></TABLE>
cause if its anything like the b18c swap you can only use the shift linkage out of a del sol vtec(b16) its the only shift linkage possible besides the adjustable.. trust me i went through 2000 civic si linkage, gsr linkage sohc del sol shift linkage.. nothing works..
and i dont know about around where your from but around here good luck finding a vtec del sol in a junk yard... i couldnt anywhere within like 100 miles..
I've done your exact swap. You can ONLY use Delsol vtec (b16 delsols) shift linkages.
Good luck with a junkyard search. You could try those aftermarket companies like Hasport etc. As for me, nothing fits better than stock--strait from the dealer.
-$200 to your wallet my friend.
passwordjdm.com has em for 200, but you have to call its not listed on the site.
i had a hell of a time finding it myself. Good luck finding it cheaper then that.
^^^^^ like SOLvtec said. I got both bars from the dealer, $99 + $69. It took a couple days to get them in though. All the misc. hardware can be canibalized off the old linkage.
powerline707
Jun 16, 2011 02:52 PM
powerline707
Jun 16, 2011 01:41 PM
skiracer8148
Mar 17, 2007 05:09 PM
SOLvtec
Oct 27, 2006 09:30 AM
