TROUBLE CODE 20 NEED HELP
Old Nov 7, 2006 | 03:37 PM
ssbpturbohatch's Avatar
Default TROUBLE CODE 20 NEED HELP
Got a 98 civic ex coupe, freshly swaped in complepletly rebuit LS motor. Check engine light comes on with a couple of codes. 17, 20, and 41. I know what 17 and 41 are, but i dont know what to look for or check for code 20::Electrical load detector):::: . Any info would be great. TIA
Old Nov 7, 2006 | 03:40 PM
bluelxfodo's Avatar
Default Re: TROUBLE CODE 20 NEED HELP (ssbpturbohatch)
20 Electrical load detector
Old Nov 7, 2006 | 03:42 PM
krazyhmongboi's Avatar
^^ beat me to it
Old Nov 7, 2006 | 03:43 PM
Default Re: (krazyhmongboi)
yeah, i forgot to mention that i know what it is, just dont know what the h#ll to do about it. Thanks for the quick responses
Anybody else?????
Old Nov 7, 2006 | 03:44 PM
bluelxfodo's Avatar
i tried lol
Old Nov 7, 2006 | 04:10 PM
Default Re: (bluelxfodo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bluelxfodo &raquo;</TD></TR><TR><TD CLASS="quote">i tried lol </TD></TR></TABLE>
yeah, i guess i screwed you on that huh?
anybody got any freakin ideas for me?????????????????????????????????????
Old Nov 7, 2006 | 05:23 PM
Default Re: (ssbpturbohatch)
ttt
really need some help guys
Old Nov 7, 2006 | 07:30 PM
jdeemseerx's Avatar
start off by making sure all of your ground wires are making good connection. then if you have a multimeter, check the output of your alternator.
Old Nov 8, 2006 | 04:26 AM
Default Re: (jdeemseerx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdeemseerx &raquo;</TD></TR><TR><TD CLASS="quote">start off by making sure all of your ground wires are making good connection. then if you have a multimeter, check the output of your alternator. </TD></TR></TABLE>
Well, i took it to autozone and had them test the battery/alternator with their tester and they said the alternator was only charging at 12v instead of the 13-14v it should be at. 2 days before that, i took the alternator up to them(out of the car) and they tested it and they said it worked like a champ, so i'm a little confused...The haynes book said that it could have something to do with anything that draws power, like headlights or fuel system and stuff like that. AAAAHHHHHHHHHHHHHHHHHHH, if i didnt shave my head, i'd start pulling out my friggin hair
anybody else??????????????????
Old Nov 8, 2006 | 07:51 AM
is everything working ok? such as lights etc..
Old Nov 8, 2006 | 09:58 AM
it starts up, runs and drives(its misfiring on my #3 cyl, i think i have a fouled plug) and all the lights and radio work like they seem like they should be
Old Nov 8, 2006 | 12:09 PM
bump
Old Nov 8, 2006 | 08:26 PM
jdeemseerx's Avatar
if your alternator checked out ok, then all thats left is the connection at your fusebox or the wire harness itself.. if you have a mutimeter check for continuity for all the wires going to your alternator. If you had a parasitic draw your battery would most likely be drained overnight. But it wouldnt hurt to do a parasitic draw test while your at it, which also requires a mutimeter.
kidcruze
Jul 18, 2008 01:45 PM
rafimos
Apr 8, 2007 09:19 PM
211811518
10
Sep 9, 2006 12:57 PM
d16rice
Jul 6, 2006 08:24 PM
jwitey
Apr 11, 2004 08:54 AM
