Good Deal?
Old May 7, 2002 | 09:08 AM
esqueleto's Avatar
Default Good Deal?
I'm looking at buying a 1991 d16a6 with 85k for 600. It comes with the tranny, brand new clutch, axles, shift linkage, and motor mounts, wire harness and ecu. But no distributor. Is this worth it since right now I have a 1990 STD with bad tranny and a bad right axle.
Old May 7, 2002 | 09:19 AM
wronghand's Avatar
Default Re: Good Deal? (esqueleto)
I think it is a pretty good deal if the motor was running good and not burning oil. Keep in mine that you will not be able to use the Si axles without changing the hubs. Your current axles will work fine though. You can use either the Si or Hf dizzy.
HTH
Old May 7, 2002 | 09:42 AM
WuShu's Avatar
New User
Default Re: Good Deal? (wronghand)
hell as long as the body is straight and is in good condition i would call it a good deal, even if the motor was shot.
k20o2o4civic
Feb 12, 2007 05:25 PM
weiRtech
Jul 20, 2006 12:32 PM
SD1222
21
Nov 25, 2004 05:41 PM
civichbb18c
Oct 22, 2003 11:26 PM
Dr. Gonzo
Jan 24, 2002 03:37 PM
