Parting Out 1989 CRX HF (Blue Interior/Blue Exterior)
Per my Signature my wife totalled my CRX.
Unfortunetly the frame is screwed. The accident only messed with the body from the firewall forward, meaning I am selling EVERYTHING from the windshield back including some front end parts such as emissions parts, brake booster, master cylinder, prop. valve, driverside headlight.
I will not waste my time figuring out how to properly ship large items such as complete doors. If you are interested in them and you are not willing to pick up then you must contact carriers about how to and how much it would cost to ship them. Then contact me. I won't waste my time just to have you back out because freight costs too much.
(All parts are from the HF and are Blue unless noted)
UPDATED LIST 3/27/07
Clear Corner Lights
Radiator Fan
Upper Radiator Mounts
Lower Fender Trim <-- SALE PENDING
Front Crossmember (Will sell the bars but not the Energy Suspesion Bushings on them)
HF Exhaust Manifold & Catalytic Convertor & Downpipe
A/C Compressor - Needs new bearing
A/C Lines
A/C Condensor and Blower Fan
Alternator
Alternator Lower Mount
Intake Manifold Support Mount
D15B6 Upper Timing Belt Cover
Master Cylinder
Brake Booster
OBD-0 Fuel Injector Wiring Harness with Injector Resistor Box Connector
OEM Open Differential with 92-95 Hardened Differential Pin (not as likely to break on you)
Speedo Ring Gear (For Small Bearing Differentials [35mm ID])
Under-hood Fusebox
Charcoal Canister
Catalytic Convertor Replacement Pipe (Resonator Shaped, 1 O2 Bung)
Full Wiper Motor and Assembly
Wiper Blade Arms (Without Blades)
Rear Subframe and Steering Rack
A-Pillar/Door Frame Moldings
A-Pillar Covers
Dashboard (Black, swapped in from another car)
--> Wiring Harness SOLD to Josh Miller (ImportsNC.com)
--> Coin Tray SOLD to Smokey2.0 (Honda-Tech.com)
Dash and Glovebox Still Available
Fuse Panel Cover
Under-Dash Fusebox
Dashboard Driverside Mounting Bracket
E-Brake Handle Cover, Rear Defrost Switch, Gauge Light Dimmer Switch and Misc. Interior Parts
Cluster Gauge Hood (Black, 90-91 = Rounded Top)
90-91 CRX HF Cluster (Can set to any mileage you want)
Stock Steering Wheel, Steering Rack, and Combo Switches
Main Relay --> SOLD
Starter Relay Still Available
Center Console
SHIFT BOOT --> SOLD
Console Still Available
Radio Bezel
E-Brake Console Cover
Carpet
Driverside Floor Mat (missing the "C" in "CRX"; Not the greatest condition)
Passengerside Floor Mat
Driver and Passenger Seats (Do have torn bolsters)
Seatbelts
Headliner
Sun Visors
Hawker Genisis G13EP
All Interior Components
The rear interior light is included (blurry pic, sorry)
Spare Tire
OEM Scissor Jack
Taillights
Invidia Catback Exhaust
Shift Linkage
Rear Bumper Cover (Bumper Support is rusted to pieces)
Spare Tire
OTHER SPARE PARTS FOR SALE:
88-91 Civic Front Mudflaps
92-95 Power Steering Pump Mount
92-95 A/C Compressor Mount
1991 Prelude Si Gauge Cluster with Connectors
Infiniti Q45 Fuel Pump Module
**** SOLD ITEMS ****
Driverside Fender --> SOLD
88-91 Civic Hatchback/CRX Hood --> SOLD to Quikshifter (CarolinaHondas.com)
Brake Booster Hose --> SOLD to CRXed (Honda-Tech.com)
Passengerside Door --> SOLD
Rear Hatch Door --> SOLD to CoolRedXylophone (Honda-Tech.com)
Hatch Shocks --> SOLD to Smokey2.0 (Honda-Tech.com)
Manual Pedal Assembly --> SOLD to babyblucrx (CRXCommunity.com)
K&N Cone Air Filter --> SOLD to Quikshifter (CarolinaHondas.com)
K&N Stock Air Box Filter Replacement (CRX) --> SOLD to Quikshifter (CarolinaHondas.com)
Motor Mounts with Prothane Inserts --> SOLD to Smokey2.0 (Honda-Tech.com)
Steering Wheel with Blue Stitching with HKS Horn Button
Sparco Civic/CRX Hub Adapter --> SOLD to Smokey2.0 (Honda-Tech.com)
Center CRX Vent with Clock --SOLD to ......
Driverside Headlight --> SOLD to 1slowhatch (CarolinaHondas.com)
Driverside Door <-- SOLD to efnastytime (CarolinaHondas.com)
Modified by BlueCrxNC at 8:50 PM 3/27/2007
Clear Corner Lights
Radiator Fan
A/C Lines
Alternator
Master Cylinder
Brake Booster
Under-hood Fusebox
Charcoal Canister
A-Pillar Covers
Fuse Panel Cover
Under-Dash Fusebox
Main Relay --> SOLD
Center Console
SHIFT BOOT --> SOLD
Radio Bezel
Carpet
Seatbelts
Headliner
Sun Visors
Spare Tire
OEM Scissor Jack
Taillights
Shift Linkage
Spare Tire
SALE PENDING FOR FOLLOWING:
$ 50 - Door Panels
$ 45 - Steering Wheel Adapter
$ 12 - Steering Wheel
$225 - Catback
$ 30 - Taillights
$ 10 - Headliner
$ 15 - Corner Lights
$ 90 - Rear Hatch with shocks
$ 75 - Full Dash
== $552
Paying me $450 to pick up.
$ 50 - Door Panels
$225 - Catback
$ 30 - Taillights
$ 10 - Headliner
$ 75 - Full Dash
== $552
Well, the website that the guy was going to be buying the parts from me on shut down the same day I gave a contact phone number to the buyer. CarolinaHondas.com was a good site
I'll give the same deal to anyone else.
