LS valve cover question
Old Nov 7, 2006 | 01:24 PM
92integracer's Avatar
Default LS valve cover question
So I have a 94 integra LS motor with the valve cover that looks like the 2nd gen integra cover. My question is that can I use later year LS valve cover on the 94 head? the reason I am asking this is that the later year LS valve cover has a hole straight across from the oil cap and almost in the center of the cover, while the 94 doesn't have this hole. Please help
Old Nov 7, 2006 | 01:31 PM
95 integra's Avatar
Default Re: LS valve cover question (92integracer)
I thought the PCV in the center was only on the CRV valve cover???
Old Nov 7, 2006 | 01:35 PM
SilverDc2's Avatar
Default Re: LS valve cover question (95 integra)
you just need to buy a different pcv valve and *maybe* the tube, shouldn't be much thought,
TheGreenOne3589's Avatar
i dont believe you can
Old Nov 7, 2006 | 01:37 PM
SilverDc2's Avatar
Default Re: LS valve cover question (TheGreenOne3589)
yes you can, i did it to my friends car
Old Nov 7, 2006 | 02:17 PM
Deluzional's Avatar
Default Re: LS valve cover question (SilverDc2)
yes they are interchangeable, just reroute your pcv valve to your valve cover instead of your intake manifold..but either way pcv is only impt for emissions
Old Nov 7, 2006 | 02:20 PM
95 integra's Avatar
Default Re: LS valve cover question (Deluzional)
PCV is actually semi-important for engine output being that it helps with blowby. As I recall, somebody (non-integra related) did a dyno of their car with the PCV unhooked and hooked up and it yielded a few extra hp with it hooked up.....given dyno graphs vary pull to pull, but he did it the same day, so Im assuming temps and such were pretty close to the same.
Old Nov 7, 2006 | 02:22 PM
Deluzional's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95 integra &raquo;</TD></TR><TR><TD CLASS="quote">PCV is actually semi-important for engine output being that it helps with blowby. As I recall, somebody (non-integra related) did a dyno of their car with the PCV unhooked and hooked up and it yielded a few extra hp with it hooked up.....given dyno graphs vary pull to pull, but he did it the same day, so Im assuming temps and such were pretty close to the same.</TD></TR></TABLE>
in that case i should have mentioned i tossed my pcv for a catch can
Old Nov 7, 2006 | 02:49 PM
95 integra's Avatar
Then you still have the PCV on the backside of the block I'd assume.....as well do most people who run breather filters.
Old Nov 7, 2006 | 03:05 PM
so are you guys saying that this is a crv valve cover? I thought that the pcv hooked up on the nubin on the back of the valve cover behind the oil cap?
Old Nov 7, 2006 | 03:10 PM
can someone post a pic of a ls valve cover (not the one with the squares) a newer one, so I can compare it with the valve cover that I bought.
Old Nov 7, 2006 | 03:51 PM
CleanLikeJdm's Avatar
Hype-R Stalker
If you use the newer one on your 94-95 engine, just Plug the whole from the newer one.
Simple as that, I'll post a pic also, h/o...
Old Nov 7, 2006 | 05:10 PM
gsr dood's Avatar
Default Re: LS valve cover question (CleanLikeJdm)
just plug the hole up
Old Nov 7, 2006 | 06:26 PM
00IntegrAllmotoR's Avatar
HT Black OPs
Default Re: LS valve cover question (gsr dood)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsr dood &raquo;</TD></TR><TR><TD CLASS="quote">just plug the hole up </TD></TR></TABLE>
Thats what she said!
Old Nov 8, 2006 | 12:36 PM
Default Re: LS valve cover question (00IntegrAllmotoR)
what did you use to plug the hole on the valve cover?
Old Nov 8, 2006 | 12:51 PM
SilverDc2's Avatar
the pcv valve,
Old Nov 8, 2006 | 06:01 PM
gsr dood's Avatar
go to ace hardware or any big hardware place and look for a nice fitting
SoSoJeff
Mar 16, 2007 06:22 AM
JLange
Jul 29, 2003 03:23 AM
93b18civic
Jan 2, 2003 05:19 PM
