ecu for d15b..
Old Nov 7, 2006 | 12:15 PM
slor209's Avatar
Default ecu for d15b..
im running a d15b with an civic ex ecu...Is there any better ecu for my d15b???
Old Nov 7, 2006 | 12:23 PM
:Andrew's Avatar
Default Re: ecu for d15b.. (slor209)
chipped p28
Old Nov 8, 2006 | 08:20 AM
slor209's Avatar
Default Re: ecu for d15b.. (:Andrew)
the p28 is my stock ex ecu correct???
Old Nov 8, 2006 | 08:22 AM
Sleepy_Red_hatch's Avatar
p08 is the stock ecu for this motor
Old Nov 8, 2006 | 08:35 AM
slor209's Avatar
Default Re: ecu for d15b.. (Sleepy_Red_hatch)
whats the p28???
Old Nov 8, 2006 | 08:44 AM
POE's Avatar
POE
is this a d15b vtec? and a p28 is an ecu that comes from a 92-95 ex. Its pretty much the same motor as the d15b vtec.
So just look for a 5 speed ecu out of an ex 92-95... P28 is the code
Old Nov 8, 2006 | 09:50 AM
DJ_SaNdOz's Avatar
Default Re: (POE)
The P28 will run rich, when I chipped my P28 I got better gas mileage, less smoke, and the engine seemed a bit smoother. In all honestly, either work fine.
Old Nov 8, 2006 | 11:25 AM
slor209's Avatar
Default Re: (POE)
yea its d15b vtec on a 95 civic coupe
Old Nov 8, 2006 | 11:26 AM
slor209's Avatar
Default Re: (slor209)
wat chip did u put in it...
Old Nov 8, 2006 | 12:58 PM
Timberland237's Avatar
p06 is the stock ecu
Old Nov 11, 2006 | 09:54 AM
williejohnson's Avatar
New User
Default Re: ecu for d15b.. (Timberland237)
i have a jdm d15b and a d16z6
d15b is quicker but smokes alittle and i get better gas millage out of the d16z6
i am running p28's on both but they are different
the p28 on my d16 is a p28-a02 came stock in my si
p28-a01 on my d15 out of a 94 ex
both cars cars run better and quicker on the p28-a01
should i just chip the p28 on my d15 or look for a p06
and if anyone wants to trade a p06 for a p28 i would love to
thank you
will
Old Nov 11, 2006 | 10:49 AM
Simon Tibbett's Avatar
p08 is the stock ECU
Old Nov 11, 2006 | 11:00 AM
Default Re: ecu for d15b.. (williejohnson)
i'll trade you i have a P06
Old Nov 11, 2006 | 12:18 PM
Jonknee's Avatar
wtf p06 is not stock ecu.
Old Nov 11, 2006 | 01:11 PM
ZCVTEC-SOHC's Avatar
From: PhantomGrayEH2, CA Where Gay Arnold Rules, USA
Default Re: ecu for d15b.. (La-Quiete)
Have a Virgin P08 for sale if you need it, hit me up.
Old Nov 11, 2006 | 02:01 PM
DJ_SaNdOz's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slor209 &raquo;</TD></TR><TR><TD CLASS="quote">wat chip did u put in it...</TD></TR></TABLE>
I chipped my P28 with P08 maps
Old Nov 11, 2006 | 06:19 PM
lek9l's Avatar
Default Re: (DJ_SaNdOz)
P28 comes in 92-95 civics that are si/ex. P08 come in JDM swaps like the JDM D15B. The P06 comes in 92-95 Civic DX.
Old Nov 11, 2006 | 06:37 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: (lek9l)
your fine with teh P28.. the diff is min..
hell i passed smog with a D15B on a P28 ECU...
Old Nov 12, 2006 | 03:38 PM
i have a 93 ex 4dr and that is the stock ecu so
Old Nov 12, 2006 | 04:15 PM
THC07's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Timberland237 &raquo;</TD></TR><TR><TD CLASS="quote">i have a 93 ex 4dr and that is the stock ecu so </TD></TR></TABLE>
then its non vtec.
Old Nov 12, 2006 | 04:22 PM
schardbody's Avatar
just add some base timing and run REGULAR unleaded.
Old Nov 12, 2006 | 04:31 PM
Default Re: ecu for d15b.. (THC07)
exactly you know what you're talking about
Old Nov 12, 2006 | 05:16 PM
schardbody's Avatar
the only differance in the p08 and p28 is the o2 heater, and a little more timing on the p08 maps.
no need to swap ecu's to get some more timing, the advance is the same, so just add some base timing to bring the whole curve up, and then you have the same maps as a P08 w/ an o2 heater.
Old Nov 12, 2006 | 06:05 PM
D16SohcVtec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Timberland237 &raquo;</TD></TR><TR><TD CLASS="quote">p06 is the stock ecu
p06 is the stock ECU unless your talking about the d15b vtec I believe that was the p08.
Old Nov 12, 2006 | 06:09 PM
schardbody's Avatar
Default Re: ecu for d15b.. (D16SohcVtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D16SohcVtec &raquo;</TD></TR><TR><TD CLASS="quote">p06 is the stock ECU unless your talking about the d15b vtec I believe that was the p08.</TD></TR></TABLE>
P06 is the stock ecu for obd1 DX non vtec models. P08 is stock for JDM d15b vtec models.
Freckles
20
May 3, 2012 06:17 AM
obuhmyuh
29
Feb 15, 2008 01:00 PM
obuhmyuh
May 6, 2007 05:33 AM
