shaft play on distirbutor?
Old Nov 7, 2006 | 12:12 PM
JSpin's Avatar
Default shaft play on distirbutor?
bought a used distributor online (i know, i know) and when i got it in the mail today, it seems to have some "shaft play". i've never really torn apart a distributor, but i assume there's a bearing or two in there. is this most likely the culprit?
Old Nov 8, 2006 | 03:38 AM
NJIN BUILDR's Avatar
Default Re: shaft play on distirbutor? (JSpin)
Yes there is a bearing in there.The obdo failed pretty regularly.It can be replaced.Do a search,I think there are some how to's out there.
Old Nov 8, 2006 | 04:45 AM
93lsd's Avatar
yes as njin said the bearings failed regularly and can be changed but how much play do you have because some is normal
jdmdelsol51
Sep 17, 2014 05:11 PM
Y2ksi
Oct 29, 2005 08:37 AM
12345
Jun 24, 2005 07:04 AM
