activating A/C without stock ECU?
How to activate the A/C without the stock Honda ECU? The A/C switch has power, but the A/C does´nt work. I guess it is only one wire I must connect, but what wire is that and where does it go?
I'm running a Mugen computer at the moment, and he needed to "short" or connect two wires that lead to the ECU.
Sorry, I can't tell you which those two are, but hopefully someone here can.
Contact King Motorsports or anyone else that has "personally" done the Mugen ECU install w/AC.
HTH Ed
HTH Ed
So you mean that there are two wires that goes into the ECU. All you have done is to cut out that two wires and stick it togehter? That would make sense. It sounds too easy.
I have a workshop manual, I must look into it, but I´m at the work now.
I want to know it now.
[Modified by austrian type-R, 6:31 PM 5/7/2002]
Is there still room left??
