White Kosei K1 +38 offset
Old Nov 7, 2006 | 08:10 AM
My95SlvrBlt's Avatar
Default White Kosei K1 +38 offset
I know these were discontinued for the longest time, but tirerack has some white ones coming in to ONE of their warehouses.
I know there were alot of people wanting these in past, great wheels all around, and easily paintable to a color of your choice.
Figured I would just let everyone know in case you wanted them in past.
Old Nov 7, 2006 | 08:42 AM
Wai's Avatar
Wai
ProFunction/GT Motoring
I thought 43mm were the ones discontinued for a long time?
I might be wrong tho....
Old Nov 7, 2006 | 08:46 AM
Default Re: (Wai)
I thought they were only 45 and 38...
The 45 is (stock offset on non ITR, not sure of ITR, I think the same though) less desireable then the 38.
Old Nov 7, 2006 | 10:17 AM
uNF$@#!'s Avatar
Default Re: (My95SlvrBlt)
50 is stock offset.
Old Nov 7, 2006 | 10:25 AM
B18C5's Avatar
Default Re: (uNF$@#!)
There were three offsets of the K1 in 15x7 with a 5x114.3 bolt pattern. There was/is the 38, a 43 and a 45. Obviously the 45s are closest to stock offset, but as far as I know are the rarest.
The optimum offset depends on the tires you're using. If you're sticking with a 205 then the 38s are nice, because they give a sharper turn-in feel. The 45s are nice because they are close to stock for a more stock feel. I like the 43s the most for a track wheel because they fit 225s the nicest. The tires rub just a hair on the trailing arm, and don't require as much massaging of the fender lip to fit on the other side. I'm sure the 45s would work just as well, but I haven't tried them yet. It's possible they might rub a little too much on the trailing arm to work properly.
Old Nov 7, 2006 | 05:28 PM
94rs-turbo's Avatar
actually i just called them today they have 16"x7.5 white set in stock for 5 lug
Old Nov 8, 2006 | 04:15 AM
Default Re: (94rs-turbo)
I am referring to the 15" not 16"
thisguyhere
Honda Civic (2001 - 2005)
16
Jun 11, 2009 08:15 AM
Integra21
Jun 25, 2005 12:51 PM
NoLipRacen
Feb 22, 2003 06:11 AM
kkim
Apr 5, 2002 03:29 PM
Yogi bear
Jul 5, 2001 04:50 PM
