Can I put S2000 on Prelude
Old Nov 7, 2006 | 07:07 AM
Dickie's Avatar
Default Can I put S2000's Rims on Prelude
I have a 2000 Prelude that needed new Rims and Tire..... My buddy have a set of stock S2000's rims for sale. I just wonder Am I able to put S2K wheel on Prelude
Are they gonna be fit
Thank You
Old Nov 7, 2006 | 07:41 AM
Slatelude's Avatar
Default Re: Can I put S2000's Rims on Prelude (Dickie)
bolt pattern, yes. something about the offsets of the front/rear being wrong, gotta use 4 front wheels or something? Its been talked about in here, look around you'll find it.
Old Nov 7, 2006 | 08:07 AM
WhiteBB2's Avatar
Default Re: Can I put S2000's Rims on Prelude (Slatelude)
In the last thread that was about this, we came up with someone that said you can use all 4 of the tires off of an S2K...So...Buy some and find out for sure.
Old Nov 7, 2006 | 08:15 AM
petern101's Avatar
Default Re: Can I put S2000's Rims on Prelude (WhiteBB2)
i thought it was the 4 rears? oh wells. basically "most" ppl that put s2k rims on have needed 4 of either the front or the back.
Old Nov 7, 2006 | 08:27 AM
WhiteBB2's Avatar
Default Re: Can I put S2000's Rims on Prelude (petern101)
https://honda-tech.com/zerothread?id=1467851
Old Nov 7, 2006 | 08:47 AM
soundbomber's Avatar
you can use s2000 rears on the rear of a prelude.
it helps that preludes don't have rear trailing arms.
TechnaF4i or whatever was running it.
the fronts of course fit on the front.
Old Jan 9, 2007 | 08:03 PM
iam7head's Avatar
Default Re: Can I put S2000's Rims on Prelude (soundbomber)
the whole set will fit, the rear wheel will have to use a 10mm+- spacer, one of my friend been running those for 3-4 years now
before you get excited...
1)handling will sucks so major ballz
2)check the rear tires, if they are s02 225 or any brand 245 width they will rub if you are slammed.
Old Jan 9, 2007 | 08:08 PM
ricoMugenlude97's Avatar
Default Re: Can I put S2000's Rims on Prelude (iam7head)
it'd be best just to run all 4 fronts.
kornkid21792
Honda S2000
32
Mar 18, 2010 09:47 AM
spoolude
Nov 22, 2004 03:52 PM
dacaveman
May 20, 2004 11:02 AM
HPrelude19
Honda S2000
Sep 14, 2002 08:59 PM
