code 21 on a 92 accord non vtec
Old Nov 7, 2006 | 07:03 AM
clutchcarter's Avatar
Default code 21 on a 92 accord non vtec
Anyone seen code 21 on a non vtec 92 accord? If so, what do you know about that?
Old Nov 7, 2006 | 08:44 AM
hondadude's Avatar
Default Re: code 21 on a 92 accord non vtec (clutchcarter)
I'd believe that the codes are a '2' and a '1' , but never seen a code 21.
Louisville is my old stomping grounds, you might want to check the O2 sensors.
If you need help call Scott at Arrons Auto Electric over in Indiana.
Old Nov 7, 2006 | 08:59 AM
Default Re: code 21 on a 92 accord non vtec (hondadude)
Thanks "Dude" we also considered that it was 1 & 2 but it displays as one code.
Old Nov 7, 2006 | 09:09 AM
NEVERMIND!!! Tech had dislexia and the rear code is 12 not 21 DUH!! Thanks anyway.
Old Nov 7, 2006 | 07:54 PM
hondadude's Avatar
that lift sensor is probably gone bad. Thats the usual problem for that code.
Salvage yard yourself another EGR valve
Old Nov 9, 2006 | 08:06 AM
had clogged passages in the intake, removed the manifold, drilled & cleaned, all good now, Thanks.
all77otorhead
Mar 5, 2024 02:45 PM
Tyrell Bivens
Jul 31, 2015 02:46 PM
Atomic646
Dec 16, 2012 08:05 PM
90da
Nov 6, 2003 10:15 AM
