Engine Swap B18C5 into a 1993 Civic Hatch EG GL
Old Nov 7, 2006 | 05:58 AM
migoi's Avatar
Default Engine Swap B18C5 into a 1993 Civic Hatch EG GL
Hi, i am new to this forums but have been reading quite alot of the guides here and the advice. The only problem is that i live in Australia and am wondering if this guide
http://www.c-speedracing.com/h...p.php
works for a 1993 Civic Hatch EG GL?
Is installing the B18C5 the same as the B18C1?
Sorry about the questions and i hope you guys can help me
Thank You
Old Nov 7, 2006 | 06:27 AM
dirtyafrican's Avatar
yes its the same thing
Old Nov 7, 2006 | 06:40 AM
pat92si's Avatar
Default Re: Engine Swap B18C5 into a 1993 Civic Hatch EG GL (migoi)
only other problem you might encounter is that if it's a jdm type r motor (which i dont think it is because you said c5) is that on the jdm type r's the axles are bigger and the stock hubs will not work.
Old Nov 7, 2006 | 08:20 AM
axtran's Avatar
wiring is a little different on the C1, you will not need to wire IAB/Secondary Butterflies in the IM.
Old Nov 7, 2006 | 08:41 AM
POE's Avatar
POE
imnot sure on the hubs, but wiring is just a tiny different
Old Nov 7, 2006 | 12:19 PM
migoi's Avatar
Ok that cleared it up a lot thanks for the input guys!
Bsmagic617
Jun 13, 2015 07:21 PM
kneeslide
12
Oct 7, 2008 11:57 AM
AcuraTypeR
Sep 28, 2002 09:08 PM
