tranny grinding bad
Old Nov 6, 2006 | 09:40 PM
whiteb16's Avatar
Default tranny grinding bad
i recently put a new clutch in my car. shortly after (i'm not sure if its related) first through third gears grind and they are continuing to get worse. it grinded before i put the clutch in but nowhere near as bad. what could be the problem?
Old Nov 6, 2006 | 10:15 PM
krisjk2's Avatar
Default Re: tranny grinding bad (whiteb16)
synchros. get ready for a new tranny, time to get a quaife lsd while you're there.
Old Nov 6, 2006 | 10:48 PM
sohc_coupe24's Avatar
you might want to bleed the clutch...if the problem persists it might be ur synchros....
Old Nov 6, 2006 | 11:22 PM
si937's Avatar
Modified by si937 at 12:23 AM 11/8/2006
Old Nov 7, 2006 | 07:51 PM
whiteb16's Avatar
Default Re: (sohc_coupe24)
i bled the clutch last night thinking that was the prob. not the case.
Old Nov 7, 2006 | 07:53 PM
whiteb16's Avatar
Default Re: (si937)
ok
Old Nov 7, 2006 | 07:58 PM
si937's Avatar
did your car sit for a long time?
Old Nov 7, 2006 | 08:08 PM
si937's Avatar
http://www.team-integra.net/fo...ion=4
Read this. might help get my point across and maybe save you some money
Old Nov 11, 2006 | 07:41 PM
whiteb16's Avatar
mawkiemarc
Aug 1, 2005 08:41 PM
deez nuts
May 13, 2005 08:30 PM
Loaded Butane
16
Aug 20, 2003 02:31 PM
J-Brooks
Dec 17, 2002 10:23 AM
